Noob
Old Oct 19, 2010 | 09:54 PM
ibmorjamn's Avatar
ibmorjamn
Noob
I am new here even though I have 15 posts. I was excited to start posting , there are many good threads here.
I am not new to turning a wrench. I worked on trucks for almost 15 years and have worked on diesel locomotives for the past 5 years. I went to Palomar college in San Marcos for their diesel program in "92"
I owned a 61 uni body in the 80's that had a 6cyl. once the engine let go I put a 302/C4 with 4v and headers. It was fun I regret having let the truck go.
So now I found a "66" long bed with a moderate rust about it. The engine is looking more like a 390 since it has a 4v manifold and a alternator. I know this is just speculation but as soon as I get another starter I'm going to see if it fires. I got another carb from the bone yard and cleaned the tank and fuel line.
James
Old Oct 20, 2010 | 01:13 AM
Bob_91SC4x4's Avatar
Bob_91SC4x4
Go for it James, these are cool trucks that deserve to be repaired and restored.
Old Oct 20, 2010 | 05:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
All 1965 and later Ford Passenger Cars, Trucks, Bronco's and Econolines have an alternator as standard equipment, as did 1963/64 Thunderbirds...the first Ford vehicles to have one as standard equipment.
The only V8 available in 1965/67 F100/350's was the 352 2V. 360/390 introduced in 1968 F100/350's, but the 390 with a 4V was not available in F100/350's until 1975.
A popular swap for these FE engined trucks is using the 4V intake manifold and carb from a 1965/70 Ford 390 Passenger Car.
Old Oct 20, 2010 | 06:23 PM
ibmorjamn's Avatar
ibmorjamn
I suppose they changed the manifold then. Either way it's going to be a fun project. I read somewhere that the trucks had generators on the 352's what ever it ends up being I will probably end up 390 or 360 if I just find a crank and reciprocating parts. I suppose that depends on the bore thickness of the block.
Thanks
Old Oct 21, 2010 | 01:31 AM
NumberDummy
Thanks
Last year for generators in Passenger Cars (except 1963/64 Thunderbird's) / Trucks/Econolines = 1964.
The 352 was introduced in 1965 F100/350's, used thru 1967 (1958/67 Ford Passenger Cars).
Old Oct 21, 2010 | 02:47 PM
garbz2's Avatar
garbz2
352's some times do not like to bore to the 4.05 of the 360/390 This is just under the maxium allowed bore for rebuild of the 352. With the large overbore the walls are thinner on a 352 and overheating or cracking can occur.
If you want a 390 look for a reverse 105 360/390 truck block and build it.
Garbz
Old Oct 21, 2010 | 03:15 PM
NumberDummy
1965/67 352/390/410/428 / 1968/70 428 / 1968/76 360/390 engines were all cast as 352's, so there shouldn't be a problem boring the 352's 4.00 bore to 4.05...since Ford did the same thing.
I did this in 1981, boring the original 352 in my 1965 F100 (with 157,000 miles) to 390 standard, then added the 390's pistons, rods and crank.
Old Oct 21, 2010 | 05:06 PM
ibmorjamn's Avatar
ibmorjamn
Boring it to 4.05 sounds good. .050" is a fair bore oversize. I have yet to see the inside of a FE but I think it would be fairly obvious if the bore is to small as garbz2 stated.
