Failed smog, no check engine light
Old Oct 4, 2012 | 08:44 PM
leslane's Avatar
leslane
1988 E250 failed smog test-again
Took a couple days off but here I am, back at it. It appears that there is no voltage to the upstream oxygen sensor between the two pipes feeding the catalytic converter. Does anyone have a schematic of where it gets its power from? I expect there is a fusible link involved somewhere in a wiring harness that will be next to impossible to find but such is life. Any help would be appreciated.
Old Oct 6, 2012 | 09:22 AM
leslane's Avatar
leslane
The service advisor at the local Ford dealership tells me that the fusible link is called "Fusible Link "N" and is in the wiring harness. He also said that it would carry no identification on it other than its amperage rating and he had no other information than that, like as to where it might be located, etc. So, the witch hunt begins. Anyone else ever have to do this?
Old Oct 6, 2012 | 06:33 PM
leslane's Avatar
leslane
Well, success! The blown fusible link "N" is just about an inch left and behind the master cylinder when you are facing it. There are 2 of them there, I checked them with a voltmeter with the key on and sure enough, one of them had no voltage and was bubbled and the insulation was soft and stretchy. I cut it out and replaced it, made a new 3 wire harness using the 2 socket ends, taped it all up and put it back together. Ready for the smog test next week. My Auto X-Ray code reader gave it a 111 "PASS" reading. So, we will see what shape the converter is in then.
Old Nov 12, 2012 | 04:54 PM
parkers5150's Avatar
parkers5150
hey Leslane, I'm in the San Diego area and just failed smog as well. are you in so cal???
Old Nov 12, 2012 | 07:47 PM
leslane's Avatar
leslane
Unhappy Failed Smog-No check engine light
Hi!
Sorry, but I live up in Northern California, just due east of San Francisco about 50 miles. Not too much help I'm afraid.
Les
Brian Goodman
19
Jun 1, 2016 12:23 PM
wstaylon
Jan 29, 2016 07:29 PM
whintyr
Mar 13, 2014 10:25 PM
Pad2383
15
Nov 4, 2012 01:30 AM
ernesteugene
16
May 18, 2010 01:03 PM
