Suggestions
Old Oct 19, 2010 | 08:43 PM
anassar11's Avatar
anassar11
Suggestions
Finally got my edge insight in and after installation I drove for about 1hr. unloaded. After 30 mins temps ranged from ECT 182-189 EOT 220-228 Btw stock gauges never moved.
Just returned from a 2500 mile trip and lost about a 1/3 gallon of coolant.
Ordering egr and oil coolers from bulletproof diesel, a coolant filter and picking up everything for flush tomorrow. Where can I get the updated fuel pressure spring?
With that type of spread, should I be concerned about anything else? Is there anything else I should do while im working on it this weekend?
Thanks in advance.
Old Oct 19, 2010 | 09:48 PM
moebdick's Avatar
moebdick
You might consider replacing the t-stat while you've got it out. Usually the ECTs run higher than 189°.
Disclaimer: my ECT was also running a tad on the low side, but a new t-stat didn't change it much.
Old Oct 19, 2010 | 10:16 PM
rocky1074's Avatar
rocky1074
With that type of spread, should I be concerned about anything else? Thanks in advance.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->You cannot just purchase the spring. You have to get the PRESSURE REGULATOR KIT # 3C3Z-9T517-AG
I got mine from:
www.partsguyed.com who is a sponsor on FTE.
The oil temp should be no more than 15 degrees hotter than coolant temp.
Old Oct 20, 2010 | 06:52 PM
Striderwv's Avatar
Striderwv
Rocky, arn't you suppose to check the fuel pressure at wot before you change the spring? IIRC too much pressure is not good also.
Old Oct 20, 2010 | 07:13 PM
cak301's Avatar
cak301
The updated fuel regulator is made to give you the proper fuel pressure provided that everything else is working correctly.
