hard starting six
Old Oct 19, 2010 | 08:28 AM
blk dog's Avatar
blk dog
hard starting six
I am restoring a 82 f100 straight 6 . Todays problem when ever the motor is operated at the normal temp for lets say15 min or more and then switched off it will barely turn over then acts as if the battery died. once engine has cooled to cold again it turns freely starts right up. Im thinking bad starter ? battery is good . this truck belonged to my father who died two years ago. it been sitting ever since.I have already dealt with fuel tank and frozen brakes , roted hoses, you know the eazy stuff. thanks for any help.
Old Oct 19, 2010 | 08:33 AM
f100jim's Avatar
f100jim
It could be a dirty or corroded connection somewhere in the wiring to the starter or in the ground path. Could be a bad solenoid or a tired starter motor.
Also, there is a wire going to the ignition module that gets 12V when cranking - this retards the timing making it easier for the starter to turn over a hot engine. I don't have the wiring diagram here, but I can check the wire color later if someone else does not chime in with it. If that line is not getting 12V it will make it harder for the starter to turn over the hot engine.
Old Oct 19, 2010 | 08:47 AM
blk dog's Avatar
blk dog
fhank you im going to check all those things before replaceing starter
Old Oct 19, 2010 | 09:14 AM
Grubbworm's Avatar
Grubbworm
I always start with these tests, and go from there.
Obviously, these tests are for a no start or no charge situation, but I always like to start with them just to eliminate the obvious.
But, if you have already eliminated the possibility of it being the battery, then you are one step further.
Old Oct 19, 2010 | 09:25 AM
Grubbworm's Avatar
Grubbworm
After I posted this, I thought a little further, and I don't think that this really applies in your situation, sorry. But, it's out there now, so you can give it a shot if you want.
Old Oct 19, 2010 | 09:58 AM
blk dog's Avatar
blk dog
um fond weird sticky rizen like goo comeing out of ignition mod think that might be problem? cant be wright. you think nappa store carrys replacement?the one iremoved say motorcraft on it Im guessing its original.
Old Oct 19, 2010 | 12:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes, the ignition module could cause this problem. If the resin on the bottom is sticky from getting hot, have the module tested. Most likely replace.
Ford still sells these brand new, and they are, by far, the best out there. But they are expencive.
They are also sold aftermarket, but stay away from the absolute cheapest ones if you go that route. The cheaper ones are not built very well.
Most autopart stores can test an ignition module.
I would also check and test the starter and the grounds to the starter. They can preform tests on the starter in most auto part stores as well if you take it into them.
Old Oct 20, 2010 | 12:40 PM
texaskid22's Avatar
texaskid22
I replaced mine when I got my truck, about 15 at oreillies, old one was still working and is stashed away in the truck
Old Oct 20, 2010 | 02:36 PM
81-F-150-Explorer
Motorcraft modules tend to let you start your truck with just a quick turn of a key.
"vrooommm..."
Aftermarket modules tend to make you crank longer before they start.
This is from personal experience.
Having an extra known working one under the seat, is very good insurance!
Old Oct 20, 2010 | 03:03 PM
LARIAT 85's Avatar
LARIAT 85
"vrooommm..."
That is EXACTLY right.
A genuine Motorcraft module is far superior to the cheaper aftermarket modules. I have had them both, and the aftermarket module I had I don't even think had the "start retard" feature the Motorcraft module did. Of course, it died after only a year. I picked up an OEM Motorcraft module from the junkyard about 3 years ago, and the box itself was larger than the aftermarket module.
In fact, with a Motorcraft ignition module - I kid you not - my carbureted 1985 F150 actually starts up quicker than my 1998 Jeep Wrangler and my wife's 2001 Ford Mustang!
Old Oct 20, 2010 | 03:24 PM
phurst's Avatar
phurst
Is this the silver box on the passenger side inner fender? I have off next week, and one of my projects is to get the truck started again. I'm going to pull the starter and have it tested, but may as well have the module tested too to avoid multiple trips.
Old Oct 20, 2010 | 08:46 PM
81-F-150-Explorer
They are located on the drivers side inner fender. Left hand drive.
Silver in color, with either a Blue (DS-II) or Yellow (DS-III) wire grommet. Fits 1980-1983 normally, but can be retrofitted into 1984 and newer.
The silver box on the passenger side is most likely the Voltage Regulator.
Old Oct 20, 2010 | 09:51 PM
ctubutis's Avatar
ctubutis
Old Oct 23, 2010 | 03:26 PM
blk dog's Avatar
blk dog
just a big thank you
I just wanted to say thank you to all you folks for the great advice. oh yea it turn out to be the voltage regulator! well thanks again! till next time. have agood one.
