The back window washer does not spray. The wiper works but the sprayer line is leaking out some where under the body, behind the passenger rear tire.
Is there a elbow that could be busted some where?
Reason: spelling
the line that runs to the window runs through the cabin on the passenger side. There is a connection by the rear window, under all the interior trim. That turns the line up to go to the lift gate. A little RTV to hold it on and its good to go.
