I have a 1994 F150 302/auto and have just replaced all the hard and soft brake lines. I have bled the system several times and with the engine off I have good pedal but, as soon as I start the truck the pedal goes to the floor. The vacuum booster check valve is working and I hear no air escaping. What am I doing wrong? I have bled the lines, master cylinder several times with no change. I'm at a loss. Thanks to any and all who try to help.
It has a bleed screw on it so is bled the same as a wheel cylinder.
The correct sequence is right rear, left rear, RABS module, right front, left front.
However a lot of guys bleed the RABS module first.
