General Diesel Discussion
glow plug codes keep setting mil light
Old Oct 18, 2010 | 11:34 PM
fastkid's Avatar
fastkid
glow plug codes keep setting 1thru 7 truck starts fine runs well check all wiring &replaced the glow plugs in that bank all seems well but keeps setting code????
Old Oct 21, 2010 | 11:26 AM
megawatt00's Avatar
megawatt00
We need a bit more info as to what year and engine you are referring to.
Old Oct 21, 2010 | 10:02 PM
fastkid's Avatar
fastkid
ok 2001 f350 7.3 power stroke the codes that keep setting is p0677-0675-0673-0671
Old Oct 31, 2010 | 04:41 PM
firefighter317's Avatar
firefighter317
id check the glow plug wiring harness for chaffing or shorts on that bank. if its only that bank, i'd say its either the glow plug control module or something with the harness. check for voltage at the glow plugs.
