Quick Turbo Cleaning Question
Old 10-18-2010, 02:06 PM
4starcstms's Avatar
4starcstms
4starcstms is offline
I am planning to pull and clean the Turbo on my '04. I've got the 'how to' PDF but it doesnt cover any gaskets/O Rings I'll be needing..
I've also got a oil leak - its running down the drivers side, Looking up from underneath the truck I can see the oil dripping out of a line on the back of the block. It has the Heat protective cover on it, and Really have not had time to pull anything apart - I figured one of the minds on here had to know what it is. I can get a pic if it'll help.
Thanks in advance!
Old 10-18-2010, 02:15 PM
High Binder's Avatar
High Binder
High Binder is offline
Could the oil leak be from your ICP?
Old 10-18-2010, 03:26 PM
rocky1074's Avatar
rocky1074
rocky1074 is offline
This kit will have everything you need O-rings;gaskets;new bolts;ect to recondition you turbo including the 3m kit 4C4Z-9V424-AA
Old 10-18-2010, 06:24 PM
amgpro2's Avatar
amgpro2
amgpro2 is offline
+1 on the ICP. It sounds like the oring on the icp is leaking. The ICP mounts to the HPOP and should be accessible once you have the turbo out. It could be lose.
Old 10-18-2010, 06:48 PM
High Binder
Old 10-19-2010, 08:51 AM
4starcstms's Avatar
4starcstms
After doing some reading last night, I'd have to agree on the ICP being the cause.
I'll admit that I've not learned as much as I should about the 6.0, but in the three years Ive had the truck, this is the first problem its given me. Guess I better step up to the learning curve eh?
Heres a pic, with the truck warm, you can watch the oil drip out of the circled area,
Thanks for the input everybody!
Old 10-19-2010, 10:47 AM
High Binder
Wow that's a lot of oil. Glad mine threw a code before it got to that point. Make sure you do the pig tails too. I got the whole kit off ebay for way cheaper than the dealer.
Old 10-24-2010, 07:32 PM
4starcstms's Avatar
4starcstms
Whew what a Day.
Turbo Removed
ICP sensor swapped (what a PITA - had to cut up a wrench to get it out/in)
ICP harness changed
Turbo Cleaned - herein lies the bad news.. I'm going to have to replace the turbo at some point in the NEAR future. Something has gone thru the turbo. The intake side fins are side, the exhaust side on the other hand - I removed a Large chunk of metal - the bottom part of the fins are flat gone, and the VGT Veins, several are severely damaged, all are seriously pitted.
Pics to Follow..
Oh, the whole deal start to finish - 3.5 hours including fighting with a stuck Y pipe to turbo clamp
Old 10-24-2010, 07:46 PM
4starcstms's Avatar
4starcstms
Pics - Sorry for the delay
No this isnt me, it's my buddy from work, Ben. Great to take his Sunday and give me a hand, guess that's what friends are for!
Old 10-24-2010, 08:43 PM
cheezit's Avatar
cheezit
cheezit is offline
whats happened to the turbo is easy to explain. the fins got stuck and over traveled. when that happens they get jammed into the compressor wheel.
the turbo is junk. this type of failer is somewhat dangrous as it can lead to an oil seal failing and a runaway engine. IMO anyway.
Old 10-24-2010, 09:25 PM
High Binder
Cheez, could you break that down for me a little more, I don't understand what would have caused that? I just cleaned my turbo the other day and it looked (aside from the soot) to be brand new but I did notice how the veins could come into contact with the fins if the fins were driven that low, is that what happened?
Old 10-24-2010, 09:27 PM
cheezit's Avatar
cheezit
cheezit is offline
pretty much what happened.
Old 10-24-2010, 09:28 PM
4starcstms's Avatar
4starcstms
That does not explain the Semi Large chunk of metal I found in the turbo - and not all of the fins were in bad shape, just about half of them.
Old 10-24-2010, 09:31 PM
cheezit's Avatar
cheezit
cheezit is offline
without a pic of the chunk I can offer no help there.
if you look at the fins you see the sides are beat up. thats from the metal of the compressor wheel.
Old 10-24-2010, 09:35 PM
4starcstms's Avatar
4starcstms
I have the chunk, I think its still up in the shop. Ill grab a pic tomorrow. I'm 99% sure that over extending the fins isnt the cause - since only about half of the fins are beat up, knicked, etc etc if the fins over extending was the cause, ALL would be chewed up in some way.
The cause, doesnt matter.
I'll get parts and fix it - I'd love an ATS turbo but... with having to replace the Oil Cooler, and doing a EGR delete, an ATS is kinda outta the budget!
Quick Reply: Quick Turbo Cleaning Question
