Quick Turbo Cleaning Question
Old Oct 24, 2010 | 10:13 PM
smokersteve's Avatar
smokersteve
What would cause them to actuate father than they should?
Old Oct 24, 2010 | 10:19 PM
High Binder's Avatar
High Binder
Originally Posted by cheezit
pretty much what happened.
Damn! Is it a bad sensor that throws the veins into the fins or some kind of debris?
Here's a before cleaning pic of mine with the veins in enough to be touching the fins. (ignore the Butterfinger wrappers they're not mine ha)
Old Oct 24, 2010 | 11:04 PM
Benchwrench's Avatar
Benchwrench
from the pic the unison ring looks busted/cracked right where they usually fail.
Old Oct 24, 2010 | 11:52 PM
High Binder
Here's an after pic, I don't think it even needed cleaning but I had it out of the truck anyways so... There are no cracks, pitting, or any galling. All in all it looks really good. I gave it a coating of anti-seize and then wiped off all I could get off. Where do they usually crack, I've never seen a cracked/bad one.
Old Oct 25, 2010 | 09:01 AM
Benchwrench
when looking at your unison ring picture (at the 9 o'clock position) where there is no vane, cracks are near the inside edge at the narrowest point. From the picture it looks like there is a crack. in the latest picture above the flash is too bright to see the same area (6:30 position).
Old Oct 25, 2010 | 12:41 PM
High Binder
Oh, interesting, must be some serious stress and/or heat cycles going on inside a turbo
thanks Bench.
Old Oct 25, 2010 | 06:53 PM
cheezit's Avatar
cheezit
its caused by unison ring and vain wear
Per4mance
Jan 25, 2017 09:32 AM
JoeF250
Jan 20, 2017 05:59 PM
Mark_in_co
Nov 16, 2016 08:58 PM
kr98664
27
Feb 7, 2016 11:37 PM
BryanStein
Sep 5, 2015 07:44 AM
