LOL another vibration thread
Old Oct 18, 2010 | 01:18 PM
oh2bnok's Avatar
oh2bnok
i did not want to high jack the other thread as my vibration issue may be different. My vibration is not intermittent. I have a 99, 5 spd 3.0, with 96,+++ miles. tthis truck has a mild vibration that I can feel in the steering column and see in the passenger seat. Through out the mph not rpm range until about 72 mph then it stops I guess. Anyway the front feels tight, new tires, ball joints, front shocks. I changed the brake pads several thousands miles ago but not the rotors. Is it possible the rotors are out of ROUND ? I don't think they are warpped as it doesn't wobble when braking that I can attribute to a warpped rotor. Also I noticed the rear drivers side axle has some in and out play like 1/4 inch. U Joints are not new but feel ok, drive shaft has the ballance and is not bent or dented that I can tell. Whats next ?
Old Oct 18, 2010 | 02:18 PM
powersmoked's Avatar
powersmoked
is this your own truck or a friends
Old Oct 18, 2010 | 02:28 PM
oh2bnok's Avatar
oh2bnok
my truck ..............
Old Oct 18, 2010 | 02:55 PM
powersmoked
you should create a detailed profile/signature. Then we would know if you had a regcab or extcab
Old Oct 18, 2010 | 03:03 PM
oh2bnok's Avatar
oh2bnok
It is an extended cab. So it makes a difference ? Can you answer my questions ?
Old Oct 18, 2010 | 03:34 PM
powersmoked
Most of the extcabs have a 2 piece driveshaft. The small driveshaft is called a yoke and needs to be cleaned and greased
They recomend a special grease. Do a search
Old Oct 18, 2010 | 03:39 PM
powersmoked
There is also a carrier bearing in the driveshaft to check
Old Oct 18, 2010 | 03:50 PM
oh2bnok's Avatar
oh2bnok
So you think the vibration is coming from the yoke not the rotors, or the rear axle ?
Old Oct 18, 2010 | 04:09 PM
powersmoked
I doubt it is the rotors since you have no braking vibration. I am not sure about the RE. I Usually suggests checking things that are maintance issues first
Old Oct 18, 2010 | 06:11 PM
Old93junk's Avatar
Old93junk
Hit a curb recently?............have your front tires rebalanced, you may have thrown a balance weight or incurred something to put a tire out of balance.
Old Oct 18, 2010 | 08:05 PM
oh2bnok's Avatar
oh2bnok
The drive shaft is one piece aluminum. The tires are balanced. Next
Old Oct 18, 2010 | 08:25 PM
Bidwell's Avatar
Bidwell
"mild vibration that I can feel in the steering column"
Go slow and open your door and look at the front tire/rim. Have a passenger do the same. A slightly bent rim would transmit to the steering column.
Old Oct 18, 2010 | 09:49 PM
bankshot's Avatar
bankshot
Had the same prob on my 2007. Here is what I did and its now gone...
Replaced tires. Replaced shocks. Alignment. Better but still vibrated.
Replaced brakes - rotors, drums, pads, shoes (NAPA Premium). Greased driveshaft yolk with Harley blue wheel bearing grease. Much better but still slight vibration.
Replaced front sway bar bushings and sway bar ends - Raybestos from Rockauto. No more vibration. Also had a clunk when going slow on gravel road - now gone.
Did this same ritual about seven years ago on a 99 Ranger except used Ford parts. Same result.
Old Oct 19, 2010 | 09:18 AM
oh2bnok's Avatar
oh2bnok
Thanks bankshot, I'll try that. I have done the tires, alignment, front shocks, brake pads. I 'll do the front rotors with a premium grade and rear shocks. The sway bar bar bushings look new , blue poly. Not sure if I have a lube zert on the drive shaft but i'll check again. see how it comes out.
Old Oct 19, 2010 | 09:41 AM
powersmoked
were both your trucks extcab? on your trucks were the driveshaft aluminum? did they both have the slip yoke and the carrier bearing?
