Steering Wheel Vibration
Old Oct 18, 2010 | 11:10 AM
wfmcbride's Avatar
wfmcbride
I’m feeling a mild steering wheel vibration; it’s most apparent for the 1<SUP>st</SUP> few miles and going up grades, the vibration is constant at any mph.
I replaced the ball joints, new front rotors and pads and the links are ok, balanced the tires and had a lineup.
I have 140k miles on truck. Any ideas?
Thanks, Walt
Old Oct 18, 2010 | 11:40 AM
thomabb's Avatar
thomabb
If it is most apparent during the first couple miles and gradually subsides, I'd think it is your tires. Is it worse when it is cold? When did you start noticing it?
Old Oct 18, 2010 | 12:01 PM
robs01f250's Avatar
robs01f250
C2 on what thomabb said. Is it worse when the truck has sat for a couple of days??
Old Oct 18, 2010 | 12:59 PM
wfmcbride's Avatar
wfmcbride
Thanks guys,
I have another year on these tires, I stayed with Firestones Steel Tex that came with the truck from the factory because I had good mileage with them. If the vibration get's worse could it be U joints or the center support bearing?
Old Oct 18, 2010 | 01:14 PM
thomabb's Avatar
thomabb
Vibrations from a bearing would not get less as it warmed up IMO.
