I was told by a local shop that I needed a right spindle bearing and spindle due to the movement (back and forth) on the right axle.
The only thing I see is that the dust cap has popped off but there is movement on the uv joint? as opposed to the left side there is none.
No noise is coming from the front end.
Are they scamming me
2002 F250 SD 7.3, 112,000 miles
