Temp gauge
Old Oct 17, 2010 | 09:24 PM
moto4's Avatar
moto4
Temp gauge
I have a 95, 4WD,4.0, about 250k miles or so. Recently the temp gauge started swinging between very low, to about midway, maybe a little more. Dosen' t seem to matter whether or not it is moving or sitting still, still swings. I replaced the t'stat, but made no difference. The heater still works quite well, but it is a little un-nerving to see the gauge move that much. Anybody got any ideas?
Old Oct 18, 2010 | 01:23 AM
g_k50's Avatar
g_k50
Might be the temp sending unit fail.
Might be the temp guage fail.
any other symptoms of fail?
Bubbles in the coolant? Brown scum on the radiator coolant?
Does it go up and stay up, or does it swing back and forth during normal operation?
Old Oct 18, 2010 | 04:52 PM
moto4's Avatar
moto4
It swings back and forth, though not fast, either way.
There is brown scum in the overflow resevior, though when I changed the t'stat, the coolant was green.
Old Oct 19, 2010 | 12:28 AM
g_k50's Avatar
g_k50
Check compression while the engine is at operating temp.
Check coolant for combustion gases.
Might be a blown head gasket.
Old Oct 19, 2010 | 04:00 AM
moto4's Avatar
moto4
What about a a bad radiator cap? I have not seen any oil or water where they shouldn't be, but I will keep checking that. Running a compression on that engine when it is hot will not be fun.
I do have a small leak (ver small) in a rear freeze plug, I wonder if it could have gotten just big enough to cause a sapratic pressure issue in the system?
Old Oct 19, 2010 | 11:53 AM
g_k50's Avatar
g_k50
I wonder if you fixed the leak would the problem with the temp gauge go away?
Have your coolant system pressure checked while the engine is at operating temperature.
