hi all! I have some questions to you. How to remove EGR from the program in ECM 5.8L e350? I want to remove completely valve EGR and its vacuum valve... And the vacuum valve from air thermactor system
That is not possible without a programmer.
You're wasting your time here there is nothing to be gained.
The complete air injection system can be removed without affecting engine operation at all, delete all the plumbing and valves, bypass the air pump, plug the back of the heads with 5/8" coarse thread bolts, and remove all vacuum lines but leave the TAB and TAD solenoids electrically connected.
