EGR Valve
Old Oct 17, 2010 | 01:36 PM
skirk55's Avatar
skirk55
EGR Valve
I went and removed my EGR valve today to clean it. I found the bottom O-Ring is bad and was leaking. My truck has used a gal of anti freeze and I wanted to see if and of the soot was wet with anti freeze. It was dry! I cleaned it put it back unplugged it and will go to my Ford Dealer for new o ring and gasket. Then I will plug it back in.I guess all of the diesel kleen and two cycle oil helped keep it clean.
Old Oct 17, 2010 | 07:54 PM
rocky1074's Avatar
rocky1074
This is the kit you will need 3c3z-9p455-ab it's about 6-8 bucks
Old Oct 17, 2010 | 08:08 PM
skirk55's Avatar
skirk55
Thank you for the help. I will pick it up after work Monday night.
