351M plumbing
Old Oct 16, 2010 | 10:36 PM
cdawley4's Avatar
cdawley4
351M plumbing
Hi,
I have a couple of questions about my 351M. I noticed that when I tore it apart, I saw this little stud sensor type thing on the engine, sort of like a coolant temperature sensor with a small screw stud for like a 5/16" nut for a small wire to go onto. Just curious as to what it is. It is on front of the engine beside the timing plate.
The other question I have is in regards to the water pump and thermostat housing. I noticed that both the waterpump and thermostat housing have a set of vaccuum line nipples on them. I don't plan on putting any of the emission control stuff back on the 351M. Could I just buy one of those plugs with a hex head on it and install it in its place to cover the hole?
Old Oct 16, 2010 | 10:44 PM
jlj6t's Avatar
jlj6t
Sounds like it's the coolant temperature sending unit.
Old Oct 16, 2010 | 10:57 PM
cdawley4's Avatar
cdawley4
If I think about it, I will take a photo of it.
Old Oct 16, 2010 | 11:08 PM
jfive's Avatar
jfive
It should be the temp sensor. And as far as the other thing goes, I have one on mine I think thats the same, and its just unhooked from everything. Post pictures though to confirm.
tbspks
Feb 26, 2009 05:37 PM
kenmaraz
Oct 27, 2004 11:16 AM
paragod
17
Oct 1, 2004 02:33 PM
jabingb
Sep 14, 2002 04:31 PM
fim
Aug 24, 2000 02:50 PM
