Sponsored by: Auxito
Help with batt dyeing
Old Oct 16, 2010 | 02:27 AM
redrock233's Avatar
redrock233
The problem is that when we do not shut the door all the way the batt will die what might be the cause to this prob. Please help this is my daughters truck. We just had the whole dash apart replacing the heater core. Any info will be gretly appreciated
98 f-150 xlt
122,000 miles
4.6 v8
Old Oct 16, 2010 | 07:33 AM
torkum's Avatar
torkum
Have you had the battery tested?
Old Oct 16, 2010 | 08:29 AM
Lime1GT's Avatar
Lime1GT
Am I reading this right? If you don't shut the "drivers" door properly? The door will be ajar and the interior lite will be left on effectively killing the battery.
Old Oct 16, 2010 | 10:09 AM
phil6608's Avatar
phil6608
+1
Shut the door!
If it still goes dead,,,test the battery.
Old Oct 16, 2010 | 12:40 PM
Bluegrass 7's Avatar
Bluegrass 7
A door left unclosed fully, will keep the interior lights on.
But, there is a timer function that will turn them off.
This feature may not be on all years.
Battery drain needs to be fully investigated and not always try relate it to only the work just done.
Reasons: the alternator may have a shorted diode stack, the regulator may be faulty or there may be some other drain unaccounted for.
Have the battery tested for load capacity.
Winter is coming, you need everything in first class condition in very cold climates.
Blackmamba333
Jan 30, 2014 06:37 PM
tyrydy
Electrical Systems/Wiring
Apr 29, 2009 03:25 PM
steve442
Sep 9, 2008 02:35 PM
hd350
New Member Introductions
Apr 16, 2007 11:57 PM
GBford
Aug 26, 2006 01:32 AM
