New Build
Old 10-30-2010, 03:36 PM
garbz2's Avatar
garbz2
garbz2 is offline
Yep, It gives it a 115" wheelbase to better center the axle in the fender opening,. something that was fixed the 65 model.
It also allows me to get enough meat to make the cut and splice. Straight up just would not accommodate.
I think next Saturday I will be able to do the big window conversion. Any one in Az wanting to come up to Glendale and help is more than welcome.
Garbz
  #32
Old 10-30-2010, 03:59 PM
Bill W's Avatar
Bill W
Bill W is offline
what time?
  #33
Old 11-03-2010, 01:31 AM
garbz2's Avatar
garbz2
garbz2 is offline
Looks like the work will start at ten am in Saturday. Again anyone wanting to stop by PM me for an address.
Garbz
  #34
Old 11-05-2010, 10:22 PM
garbz2's Avatar
garbz2
garbz2 is offline
Got a bit more done to the truck frame.
Here is the main section welded
Here is the upper filler piece in place
I will add the lower sections over the weekend and make the fishplate templates.
Here a a few of the goodies we will install in the build.
I will document the install of the rear big window with lots of pictures.
Garbz
  #35
Old 11-06-2010, 08:33 AM
dman2008's Avatar
dman2008
dman2008 is offline
Is that a big fuel tank? Who makes that?
D
  #36
Old 11-06-2010, 10:20 AM
garbz2's Avatar
garbz2
garbz2 is offline
It is a Vintage 15 Gallon Moon fuel tank.
Aluminum with the mounts and an indy type flip cap.
Garbz
  #37
Old 11-06-2010, 02:43 PM
Ringo Fonebone's Avatar
Ringo Fonebone
Ringo Fonebone is offline
Good stuff so far Dave. I am gonna be watching the roof stuff with interest. Nice work. Guess you have to live in Az to start a project like this in November
  #38
Old 11-06-2010, 09:22 PM
garbz2's Avatar
garbz2
garbz2 is offline
Yea John, Arizona Fall and winter is the build time it was in the low 90's today.
Here is some more work done. Eric, BillW and Kstone came over to help.
Here is the donor roof.
Removing the excess sheet metal so we can have it bead blasted.
Kstone removing the excess metal.
BillW and Kstone with the almost ready piece.
Here is where Eric starts to remove the rear sail panel and inner structure.
Once all the spot welds inside are removed we cut all around the panel.
Here is the side cut where the splice of the new big window roof will meet the existing cab sheet metal.
Here is the panel fully removed.
I hammer and dolly worked the back edge of the cab to make a flange at the existing body line.
And that is about it for today. I need to remove the remaining sheet metal from the flange on the cab roof and once the rear big window panel comes back from bead blast i will need to do some rust repair.
Garbz
  #39
Old 11-07-2010, 12:01 AM
unibody madness's Avatar
unibody madness
unibody madness is offline
I am turning green with envy, you guys have some mad skills. Keep them coming.
I just wish I had the skills to straighten what little is wrong with my project
  #40
Old 11-08-2010, 08:50 AM
DREW148BHP's Avatar
DREW148BHP
DREW148BHP is offline
That looks great!!!
  #41
Old 11-09-2010, 02:11 PM
garbz2's Avatar
garbz2
garbz2 is offline
Drew,
I am pretty sure we will hit roundup in Austin with this truck and my 63. See ya there.
Garbz
  #42
Old 11-10-2010, 08:44 PM
unibodyslick's Avatar
unibodyslick
unibodyslick is offline
How close do the B pillars line up? Any pics with the BBW set in place? Looking good. Theres nothing like having good help also.
  #43
Old 11-11-2010, 09:04 AM
garbz2's Avatar
garbz2
garbz2 is offline
I will get the section back from bead blast today. I have some rust repair to do and then fit it in place.
The B pillar inner stamping for the latch and the outer riser to the roof are the same stamping for the conventional and the uni cabs. There is a different inner reinforcement for each tyupe of cab. The small window uni differes from the big window uni and these differ from the conventional.
The Big window also uses a upper inner panel that has the dome light integral to it. It uses a one piece headliner unlike a small window two or four piece.
Also being dropped off today is the new wiring harness, and all the parts to rebuild the steering column for the firewall outlet relocation.
I should be able to have the BBW in place this weekend. Stay tuned for updates.
Garbz
  #44
Old 11-13-2010, 05:32 PM
garbz2's Avatar
garbz2
garbz2 is offline
Was able to get some more done today.
Here is the opening being prepped
Here is the rear window panels after media blast. There is a substantial bit of rust needing repair in the upper window stamping.
I removed the upper center to make it easier to metalwork and placed the panel in the cab.
From behind.
From the drivers side
From the passenger side
From the inside
From the inside
I need to add some sheet metal to the cab at the base of the sail panels on each side and add a flange to the outside to pick up the lower outer window panel.
Eric brought some more goodies by for the build. A E Z Wire kit, and components from Dennis Carpenter to remake the 64 column.
Garbz
  #45
Old 11-13-2010, 06:34 PM
Bill W's Avatar
Bill W
Bill W is offline
why did you cut out the top center section?
Quick Reply: New Build
