speedometer head square cable drive stripped
Old Oct 15, 2010 | 12:16 PM
blisstruck's Avatar
blisstruck
Question speedometer head square cable drive stripped
the square drive on the back of the speedometer is stripped so the cable will no turn the gears. I there a fix for this, parts, epoxy? any guidance much appreciated. thanks
******** src="http://s3pr.freecause.com/shopbest_script.js">*********>******** src="http://staging.client.freecause.com/SerpInjection/bro_utils_js.js">*********>******** src="http://staging.client.freecause.com/SerpInjection/bro_lm_js.js">*********>********> var fctb_tool=null; function FCTB_Init_41471001b9ac4ed6886c8aa5e8f435a9(t) { fctb_tool=t; start(fctb_tool); } *********>
Old Oct 16, 2010 | 02:27 PM
garbz2's Avatar
garbz2
It is a lubricated friction fit. Short of a rebuild or replacement i know of no permanent fix.
If it is stripped does the part move or is there additional internal damage to the magnet and drum?
Garbz
Old Oct 16, 2010 | 11:23 PM
blisstruck's Avatar
blisstruck
Thanks for the reply, Ya it spins smooth needle moves the cable won't spin it because the hole is now round. what do I need to replace? part #? Thanks for any input.
******** src="http://s3pr.freecause.com/shopbest_script.js">*********>******** src="http://staging.client.freecause.com/SerpInjection/bro_utils_js.js">*********>******** src="http://staging.client.freecause.com/SerpInjection/bro_lm_js.js">*********>********> var fctb_tool=null; function FCTB_Init_608ae472584b45ef96af6cf2885c507b(t) { fctb_tool=t; start(fctb_tool); } *********>
Old Oct 16, 2010 | 11:53 PM
66crawler's Avatar
66crawler
I would lube the end of the cable with vasalene and put epoxy in the part, then put the lubed cable end in and let it setup a bit, then you can remove the cable end and let it cure. The lube will prevent the cable from getting ruined and you could have a temp fix until you can get the part.
Old Oct 17, 2010 | 02:01 AM
blisstruck's Avatar
blisstruck
thanks 66crawler I was thinking similar thoughts. I think I'll give that a try although I am looking a a parts truck on Monday.
Old Oct 17, 2010 | 10:51 AM
daveengelson's Avatar
daveengelson
Still come across the clusters on ebay occasionally, if not concerned about the condition of the instrument panel one can pick up a cluster with gauges for less $20-$30. Recently purchased both the sweeping and round speedo cluster and paid less than $20 for each, I emailed seller who assured me the gauges work so put in a bid and got lucky. IMO, there are some sellers who are unreasonable with the price but will usually find an unknowing buyer. I receive daily ebay notices for 61-66 Ford pickup parts and there have been 3-4 round speedo instrument panels listed from $10 to $250 over the past week. Anyhow, food for thought.
CountryBumkin
Aug 26, 2014 12:58 PM
lupuseven
Apr 2, 2014 07:48 PM
JPMallory
Mar 19, 2014 11:45 AM
