Strange fluid leak
I am glad that you posted the pictures that you did Lloydable, If anyone could answer this for me. In the first picture on the lower right I am having a drip leak at the lower water pump hose area. It is between the flange and the water pump and not where the hose is pushed into the flange. I went to "O'Reilly" to buy a "gasket".... The guy looked at every manual he had and his computer (and he looked at my truck) and he said that he could not get a 'gasket' for that. Is that 'true'? Is there no 'gasket' between the hose 'flange' and the water pump?
Sorry for the hijack
Be very careful when taking off the top flange off the water pump as it is most likely 'rusted' on and may snap off if a lot of liquid wrench is not used.
I am pretty new to this.
I am not sure what this is "if a lot of liquid wrench is not used"
So when it dumps out, what needs to happen after?
Is there a write up for this fix somewhere. I would hate to disable my truck for something so simple.
Are you referring to undoing this "bolt"?
I believe that that is where your original leak was coming from and dripping down to the lower bar.
I have not worked on the water pumps from these (our) trucks. (hence my question about a gasket or sealant between the lower flange and water pump).
You will need to drain the radiator down below the level of the center of the water pump fan before you take the hose off.
have you looked on the "Search this Forum" feature? That is why I am not taking my lower hose off until I find out about the gasket or not. My leak and yours is not bad enough to have a truck down because of broken or no parts. It does need to be fixed though and should be an easy fix, just don't break that flange nut or distort it.
Well, if you haven't changed the coolant since you got the truck and you don't know when the PO did either, it might be a good excuse to just drain it and do it over again... it takes alot of the guesswork outta the job. Mine was pretty dirty and when I accidentally got my upper radiator hose dislodged and the belt burned a hole through it, I just changed the coolant altogether. Be careful to use a good wrench, if not a deep 6-point socket so you don't mess up the head. Also, the water pump housing is only cast... "Liquid Wrench" or "PB-Blaster" might help as well. I would recommend PB-Blaster just because when my Grandpa tried it on bolts he'd already put Liquid Wrench, it loosened them right up.
If the fitting he's got fussing at him is like I think it is, I don't see why you couldn't add an O-ring... it seems to be similar to the fitting that came outta my HPOP that had the blown O-ring. Think it'd work?
I believe I got one from the Federated Auto parts place by me. Might have been the same as the thermostat ( just guessing, been a while) but that kind of rings a bell, also pretty sure they come with the waterpump. Bottom line is I know there was a o-ring there, hope this helps. I know I'm not the sharpest chisel in the shop...lol
Lloydable
11-03-2014 08:50 AM
Lloydable
06-16-2014 09:29 AM
