Brake light ?????
Old Oct 14, 2010 | 07:52 PM
F1 48 Ford's Avatar
F1 48 Ford
Question Brake light ?????
I finished wiring up my 48 and all the lights are working.The problem I'm having is when I apply the brakes not only the tail lights work but the parking lights in front come on also. Any one have any ideas where I screwed up????????????
Old Oct 14, 2010 | 08:06 PM
harleymsn's Avatar
harleymsn
Well that depends on where you wired the brake light switch to. Some of the old axillary signal kits had the brake lights wired into the switch. If that is the case, it sounds like you have the front and rear turn signals both running off the same lead. In other words left signal, front and rear off the same terminal and the same on the right. That is assuming that you have the parking light wired as turn signals also. If they are not, then you have the brake lights wired to the parking lights rather than the turn signals.
Old Oct 14, 2010 | 08:48 PM
Julies Cool F1's Avatar
Julies Cool F1
Do you have turn signals?
Chances are you have a wire crossed at the truns signal switch. Or you have your parking lights wired off the signal switch (and not the headlight switch) and didn't convert to two wire two post sockets up front. The two post sockets take signal power from the signal switch and parking light power off the headlight switch!!!!!
If you didn't change the sockets, no workee rightee!
Here is a basic light and headlight switch wiring diagrams for the Bonus and Economy built trucks. The signal switch in the diagram is for a 7 wire "Everlasting" type. If you have a different switch let me know.
Name:  H F1 Headlight Switch Wiring.jpg
Name:  R F1Generic Light Wiring Diagram.jpg
PS: "HOT BUS" is hot power supply that is always on (not turned on and off with the ignition switch) "SWITCHED BUS" is power in that is turned on and off with the ignition switch.
Old Oct 14, 2010 | 11:25 PM
51ford52's Avatar
51ford52
brake lights
check the bulbs on both brake lights,if the brake filement is touching the tail light filement it will feed the parking lights too.
Old Oct 15, 2010 | 01:18 AM
Julies Cool F1
Not true. The parking lights are powered off an isolated circuit from the headlight switch and are not connected in any way to the running lights or brake lights except that they use a common ground. And power does not flow backwards up from ground. Please see the diagram above.
Old Oct 15, 2010 | 10:05 PM
abe's Avatar
abe
I'd keep it as it is. Now you have front brake lights! The people in front of you will know that you are slowing down. Who know, maybe the Auto manufacturers will use your ideas on the 2012's.
Old Oct 16, 2010 | 12:14 AM
Julies Cool F1
LOL now that's funny Abe!
Hey look at the bright side, you can drive around in reverse all the time and still be legal!
Magnumu
2009 - 2014 F150
Dec 28, 2016 11:31 AM
Rsnake69
Aug 20, 2016 09:37 AM
F-1
Apr 17, 2016 12:50 PM
Irish916
Jul 19, 2015 07:16 PM
Calvin Cheney
Jan 11, 2011 03:43 PM
