8.8 wants out
Old Feb 23, 2003 | 11:26 PM
JjimrB's Avatar
JjimrB
8.8 wants out
96 F-150,2wd160,000 miles. 8.8 rear has had enough, whines real bad. Started not so bad, now pretty well screams. Was told 4wd models had 9inch rears. Would love one in mine, didn't seem likely tho. Figure a 9inch can bolt in ok, but was wondering about speedo hookup. Have learned speedo reads from the rearend on my 8.8. Assume this isn't so on the 9inch? Was a 9inch ever installed in a computer era F series?? Thanks in advance for any help. Oh, my trans is the AOD-E. I figured that would go long before the rear.
Old Feb 23, 2003 | 11:32 PM
steve83's Avatar
steve83
8.8 wants out
9" was NOT used after '86, when RABS became standard. You MUST have the ABS sensor in the rear end for your speedo, cruise, ABS, and transmission (which is either the E4OD or the 4R70W - post the code from the door sticker). PM or e-mail me if you want a good '96 8.8".
Old Feb 23, 2003 | 11:59 PM
Racerguy's Avatar
Racerguy
8.8 wants out
Chances are your problem is your pinion bearings are shot. You might want to get it checked out and get a couple quotes on replacing them. Unless you have a good selection of tools it's probably not something you want to tackle at home as you need a press etc.
Old Feb 24, 2003 | 05:12 AM
mooktank's Avatar
mooktank
8.8 wants out
its probably more trouble than its worth. If you want a new axle get a 10.25" or another 8.8"
morrisford96
Jan 30, 2007 06:42 PM
84tealbeast
Sep 14, 2006 02:20 PM
Blueovalguy88
19
Mar 5, 2006 12:34 PM
imbroncitis
Apr 27, 2004 11:05 AM
f-150rebel547
Jul 2, 2003 09:58 AM
