Cam shaft sensor Code 0340 HELP
Old Oct 14, 2010 | 04:52 PM
red101's Avatar
red101
Hello first time on website.
I put new gaskets on my upper intake (plenum). the 0171 codes are gone but now I have the o340 cam shaft censor codes. When I fired up my engine after doing the plenum gasket procedure I put a wire on the wrong plug and it misfired. Can that cause the sensor to go bad? Do I need to reset the sensor? If so how? The engine is an 4.0 OHV.
P.S Where is the sensor on this engine?
THANKS
Old Oct 14, 2010 | 09:16 PM
shorod's Avatar
shorod
Welcome to the forum!
What year is your Explorer? Putting a plug wire on the wrong plug should not cause a CMP sensor code.
-Rod
Old Oct 15, 2010 | 02:13 PM
aquanaut20's Avatar
aquanaut20
The cam shaft sensor is just below the coil pack, you might have pinched/disturbed a wire..
Old Oct 15, 2010 | 05:47 PM
red101's Avatar
red101
thanks guys
thanks guys the explorer is a 1999
