Sponsored by: Real Truck
Vibration while towing
Old Oct 14, 2010 | 03:00 PM
Offsore Racer's Avatar
Offsore Racer
I have a 2011 F250 and when towing I get a strong vibration at start through about 25 mph. My dealer say's there is nothing than can be done, anyone have this type of issue? If so is there a solution?
Old Oct 14, 2010 | 05:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hi Offsore Racer. Welcome to FTE.
Go to another dealer. Shudder while taking off (especially when towing or hauling) is a fairly common problem, usually solved by shimming the carrier bearing.
There is a TSB on it, viewable here, although not sure if it applies to the 2011 models:
09-20-5*** SHUDDER OR VIBRATION ON ACCELERATION - ESPECIALLY WHEN LOADED
Old Oct 14, 2010 | 07:07 PM
senix's Avatar
senix
yup, when towing fairly heavy or full throttle take-off situations your drive line angle changes causing this.
If it is really consistent shim the carrier bearing as Redford suggests. Usually your local 4x4 shop will have a spare shim they may just give you to do the job. You don't need much, no more than 1" and see how she does.
Old Oct 15, 2010 | 09:19 AM
Offsore Racer
The dealer said if you shim it vibration will occur during normal driving. Anyone have this occur??
Old Oct 15, 2010 | 09:32 AM
senix's Avatar
senix
It can be a dual edge sword. You may encounter or may not. That is why I would suggest no more than 1" shim. That may or may not be too much.
You will have to experiment.
Old Oct 15, 2010 | 09:38 AM
DAVE67FD's Avatar
DAVE67FD
It may depend on the amount of shim. I would start with a 1/2" inch shim. Demand that the dealer take care of this. If not call around to another dealer. It's a pretty easy and cheap job and shouldn't take you all of a 1/2 hour and i would only do this if you get continued aggrivation from the dealers.
You shouldn't notice any vibration with the 1/2" shim unloaded.
