Overheating Problem
Old Oct 14, 2010 | 05:07 PM
craftsmangary's Avatar
craftsmangary
Originally Posted by riverrat41
I understand what you are telling him but that is an external cleaning.That may need to be done but if the radiator is stopped up internally it will need to be done at a radiator shop.
Thats right, but you wouldn't believe how dirty the fins get, when I get a complaint like the OP I clean the radiator and that almost always takes care of the overheating problem, even cleaning the A/C condenser will made the A/C work better.
Old Oct 15, 2010 | 05:34 AM
Muktown's Avatar
Muktown
I agree with rog. My guess would be the temp sender. These trucks have very efficient cooling systems. I would flush the radiator and also a plugged heater core can cause a vehicle to run hot. Flush that too.
Old Oct 15, 2010 | 09:33 AM
gomfrddy's Avatar
gomfrddy
Originally Posted by kawa
Let me see if I understand this correctly.... as you increase your speed to 55 MPH the stock temp gauge goes to center and you think that the temp is rising so you back off. Do I have this right?
Before I did anything further I would get a infra red thermometer (No contact) drive the truck until you think that it is HOT, immediately stop and take it's temp on the water pump. These rigs, as a rule don't generally over heat. What is the condition of the coolant? Is it cruddy?
Helifixer is right, put the RIGHT thermostat back in, it is a needed item. You may very well need all that has been suggested but I am leaning towards the gauge/sender, It's an Idiot light with a Pointer.
Rog
no if I stay over 55mph...it will indicate that it's gettting hotter and hotter...the first time I noticed it was 3/4 of the way on the gauge
Old Oct 15, 2010 | 11:14 AM
triskadek's Avatar
triskadek
I don't think it was mentioned, but has the hose in to the rad been checked? If it has collapsed it will kill the flow.
Old Oct 15, 2010 | 12:27 PM
guywhalen00's Avatar
guywhalen00
I work as a diesel mechanic on heavy trucks. Every spring we wash out tons of radiators. try that. And put your t stat back in
