Tire PSI while towing
Old Oct 12, 2010 | 07:03 PM
hifiman's Avatar
hifiman
Hi All
I am leaving tomorrow on a trip and will be towing a 7-8k lb travel trailer. I have a 2005 F350 and the door sticker says tires should be 65 up front and 75 rear standard. I have stock tires. Cant remember who makes them but on the tire it says 80psi Max load. The tire name starts with a C if that helps. Should I fill all four to 80psi? Thanks
Old Oct 12, 2010 | 07:12 PM
69cj's Avatar
69cj
Originally Posted by hifiman
Hi All
Mine says 60 up front and 75 at rear and that is what I go by. My tires are Pirelli Scorpions and are the factory tires. I tow a 31' 5er and loaded is probably 13 to 14 k.
Old Oct 12, 2010 | 07:18 PM
amgpro2's Avatar
amgpro2
I have nitto dune grapplers and say max wait at 80 psi. I tow a 15-16K 5er toy hauler and usually run my fronts at 75 and rears at 80. I get a little more squirm at lower psi but that might just be because of the type of tire I use.
Old Oct 12, 2010 | 07:23 PM
hifiman's Avatar
hifiman
Thanks. They are Conti Trac TR tires. I am hearing I should start out at door spec and adjust if needed. Thanks again.
Old Oct 12, 2010 | 07:32 PM
69cj's Avatar
69cj
Door spec is what the vehicle is designed for with the stated gvwr.
Old Oct 12, 2010 | 09:55 PM
mhoefer's Avatar
mhoefer
small trailer, 65 psi front, 68 psi rear is about right for me.... Load truck too, then try 75 rear....
Gundown64
2004 - 2008 F150
Apr 16, 2014 03:51 PM
ddivinia
Dec 26, 2012 07:10 PM
bigtexan99
20
Jun 26, 2010 11:04 PM
NoBite
All Things Towing
20
Jul 9, 2007 09:20 AM
johnk8jb
Jun 30, 2001 09:49 AM
