Which brand ATF
Old Oct 12, 2010 | 05:57 PM
locknload223's Avatar
locknload223
Which brand ATF
I've been searching and see Mercon V is the juice to use but didn't see a prefered brand. How's the Walmart fluid? I see somethere are listed as a multi fluid and say Mercon V compatable but will that work or should I look for strictly Mercon V? I need to change the fluid here pretty soon. Thanks
Old Oct 12, 2010 | 06:01 PM
big poppa's Avatar
big poppa
Wal-mart carries the Vavoline Max Life, good stuff right there, Got it in mine. I'm sure the Wally's brand isn't bad but can't bring myself to using their fluids.
Old Oct 12, 2010 | 06:17 PM
locknload223
Is the max life considered a multi oil or Mercon v? I think I'm getting hung up on the term, multi oil.
Old Oct 12, 2010 | 06:32 PM
big poppa's Avatar
big poppa
Yep, but most trans fluids are going that way. Very confusing but I know this stuff is good stuff, its synthetic also so your in good shape. If you look its on sale sometimes, you can score a deal but its normally in the 3.00-4.00 a quart range. Heres a link. Valvoline.com > Products > Automatic Transmission Products > Automatic Transmission Fluid > MaxLife® DEX/MERC ATF
Old Oct 12, 2010 | 06:54 PM
locknload223
Thank you sir!!
Old Oct 12, 2010 | 07:28 PM
big poppa's Avatar
big poppa
Glad to help.
Old Oct 12, 2010 | 07:46 PM
Bigcat350's Avatar
Bigcat350
Have you checked your local Ford dealer? I couldn't believe it but mine had the best price so why not support them if they can compete plus you get the Motor-Craft Mercon V.
Old Oct 12, 2010 | 07:52 PM
nissandoc's Avatar
nissandoc
I use BG Products synthetic. Its not available over ther counter though. We use it at work for the trans flushes. If you found a local shop that is a BG user they may sell it to you.
Old Oct 12, 2010 | 08:35 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I was thinking the same thing. I think Mercon V might be a trademarked term and under Motorcraft license. It's their brand or their specification or something like that. Every other trans fluid brand that I've looked at said "Mercon V compatible" or "meets Mercon V specs" etc.
Add to this the issue between Mercon III and Mercon V becoming backwards compatible, and things get even more confusing. Do a search here and you will find that lots of owners have found a brand they like and use with good/great results. I ended up going with Motorcraft because I think it's quality fluid and I know I can get more of it anywhere I go as long as there is a dealership nearby. If I were to switch to a different brand, I may not be able to find it later if I need some more for whatever reason.
The one thing that still confuses me is the synthetic vs. syn/blend vs. non-synthetic fluid. I mean, isn't all trans fluid a synthetic of some sort anyway? Does anyone make trans fluid that has a petroleum base?
Anyway, the Motorcraft Mercon V might be reasonably priced from your dealer if you check.
BAD RONALD
Jun 10, 2013 09:48 PM
villestrip
Feb 25, 2009 11:16 AM
RobertJohn
Dec 15, 2007 01:06 PM
JFUSION
Escape & Escape Hybrid
Nov 21, 2006 08:34 AM
Joe Finn
1997 - 2003 F150
32
Mar 18, 2004 02:32 PM
