Engine question
Old Oct 11, 2010 | 08:21 PM
tonygus's Avatar
tonygus
Engine question
Hello Everyone,
I recently bought a 2002 ford expedition with 167,000 Kilometers
After doing an oil change, the exhaust was blowing white smoke like crazy.
We then took out a full liter of oil and ran the truck again. After doing so, no more smoke.
I ran the truck again for 30 minutes and no more smoke came out. I then decided to do a compression test just to be sure and here are the results:
1. 120
2. 115
3. 90
4. 115
5. 120
6. 120
7. 110
8. 120
What does this mean? I have had 3 different answers from 3 different mechanics. Can anyone help?
Thanks,
Old Oct 11, 2010 | 09:25 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
It means you have low compression in one cylinder.
You now need to perfrom a leak down test to determine if you have an issue with the rings or the valves. My guess would be that you have a valve not sealing properly on the offending cylinder.
Old Oct 11, 2010 | 09:27 PM
tonygus's Avatar
tonygus
Thanks for the reply..
If it was a valve, would this be a costly repair?
Old Oct 12, 2010 | 07:15 AM
Big Greenie
The cylinder head must be removed to make the repair. That is a fair amount of labor. If you can pull the head yourself, they repair would probably be less than $200, if all you do is fix the issue.
Old Oct 12, 2010 | 10:55 AM
dirtmonkey11's Avatar
dirtmonkey11
To me it either looks like the rings are leaking or a valve is not seating all the way allowing compression to pass by it.
GasserGary
Nov 6, 2016 09:54 AM
GasserGary
Oct 31, 2016 01:01 AM
littlerebel99
Feb 4, 2016 01:25 PM
MudhenGIB
Nov 29, 2015 09:18 PM
Crashman927
Mar 16, 2015 10:57 AM
