random stalls
Old Oct 11, 2010 | 07:54 PM
1997f350stroker's Avatar
1997f350stroker
random stalls
hi i have an automatic in my 97 psd and sometime when im coming to a stop like at a stop light it will get really low with rpm's then stall out. any ideas of what it is?
Old Oct 11, 2010 | 08:38 PM
fordpride's Avatar
fordpride
mine did that a couple of times changed the CPS ( cam shaft sensor) and hasn't did it again
Old Oct 11, 2010 | 11:21 PM
wmiller's Avatar
wmiller
Does it pull down like your stalling a standard or is it act like no fuel?
Sounds like CAM sensor or possibly TC but usually if they are going it will do that in reverse
Old Oct 12, 2010 | 02:31 AM
RubberDuck's Avatar
RubberDuck
I'd try the cam sensor first, but it sounds like the converter may not be unlocking.
Old Oct 13, 2010 | 05:18 PM
1997f350stroker
when im stopping it will get low for a second then just drop down and stall out
Old Oct 13, 2010 | 05:19 PM
1997f350stroker
it will start right back up and wont do it again for a week or two
Old Oct 13, 2010 | 06:52 PM
fordpride's Avatar
fordpride
try this the next time you drive it get up to 55MPH with one foot still on the gas take the other foot and tap the brake watch the RMP's and see if they jump up a little when you hit the brake if it does then the TQ is unlocking
Old Oct 13, 2010 | 07:11 PM
CampSpringsJohn's Avatar
CampSpringsJohn
How many miles on the truck? My 97 did that a couple times. One time it was in need of a tranny rebuild because the TQ was locking up. (Do this test when the truck is warmed up.) Check if it does it in reverse, and when shifting into manual 1st gear. If it acts up when doing either or both of those situations, then get ready for a tranny rebuild. If that doesn't do anything, then you're probably looking at replacing the IPR o-rings, or just replacing the IPR.
Old Oct 14, 2010 | 07:55 AM
1997f350stroker
the trucks got 160000 and what is the IPR.thank you
Old Oct 14, 2010 | 02:00 PM
CampSpringsJohn
Injection Pressure Regulator.
Old Oct 15, 2010 | 07:19 AM
1997f350stroker
tried what u told me to yesterday
1997f350stroker
it does not do it in revorse or manual. so im going more towards the IPR
Old Oct 15, 2010 | 05:41 PM
fordpride's Avatar
fordpride
have you tried a new CPS?
Old Oct 18, 2010 | 07:33 PM
1997f350stroker
I have put a new one in about three months ago.don't think it would
be that. Or the torque converter. This is I am so confused.
Old Oct 18, 2010 | 07:43 PM
427 fordman's Avatar
427 fordman
I'd still try another cps. If you got one at a parts store they are known to be less reliable, may last a day, maybe a year, luck of the draw. Easy check. Need a spare anyway. Get one from ford or ih, better but still can quit.
scootin
May 18, 2010 08:13 PM
RDouglas
1997 - 2003 F150
Apr 22, 2009 08:39 PM
jsphsol6
Jun 17, 2007 12:24 PM
thecookiemaker
1983 - 2012 Ranger & B-Series
Jun 4, 2006 01:16 PM
truckin77
Apr 12, 2005 10:09 PM
