302 efi problem
Old Feb 23, 2003 | 05:19 PM
jameslfusco
Guest
Posts: n/a
302 efi problem
I have an 86 f150 with a 302 efi engine. I just did a full tune up on it. New cap, roter, plugs, wires, and coil. It is running much better now, but it still has alittle hesitation when i get on the gas. A small hitch in the gedeup. If you know what I mean. It is not bad, but would like to figure this one out also.
Thanks.
Old Feb 23, 2003 | 07:58 PM
ratstang's Avatar
ratstang
302 efi problem
Try replacing the EGR Position Sensor (EPS). After that I would try the Throttle Position Sensor (TPS). They are both carbon film resistance type sensors and prone to failure.
