temp sensor install
Old Oct 11, 2010 | 10:29 AM
timmyboy76's Avatar
timmyboy76
temp sensor install
Sup y'all........i've got the fittings to mount my sensor on the auxilary port, off the thermostat housing, in which, my DIY external coolant filter kit, is from same port, no biggie, i got the extra fittings, to tap into it. However, i'm wondering, since i'm gonna flush the system and install the new ELC coolant, the question is, can i tap/thread my sensor, into one of the "plugs" on the block, that are used to drain the block as well? Thanks again FTE.
