Clutch, Transmission problems
Old Oct 11, 2010 | 01:00 AM
Joefish1943's Avatar
Joefish1943
My son has a 84 F250 4x4. it has a 460 engine with a T-19 4 speed.
The problem is he can't get it gear when its running its like tryimg to put it in gear without pushing the clutch in.
New Pressure plate, clutch, throwout bearing and drive shafts, he's had it apart 5 times but can't find whats wrong, he says that the pressure plate go all the way but it won't let it go in gear.
Joe
Old Oct 11, 2010 | 01:22 AM
Beechkid's Avatar
Beechkid
Joe
Hydraulic clutch slave is dying or..it has the wrong pressure plat or throw out bearing.
Old Oct 11, 2010 | 04:09 AM
Lazy K's Avatar
Lazy K
Is the clutch friction plate installed the right way round?
Old Oct 11, 2010 | 01:07 PM
85e150's Avatar
85e150
'80s trucks had firewall flex issues. Add the years and you get rust, and could end up with cracks. As part of running this down, check the master mount as the clutch pedal is depressed, watch for movement. A moving master cylinder will soak up enough travel to reduce movement at the pressure plate enough to cause shifting issues. It will also cause binding and hard clutch pedal movement.
Also check the hydraulic lines for bulges--again, if the line bulges, the pressure is not being applied where it's needed.
Old Oct 15, 2010 | 11:26 PM
Joefish1943
thanks for the advice
Hes replaced the Clutch, Pressure plate, Throwout bearing and Slave cylinder.
he says that when he holds the clutch in, the arm on the throw out bearing pushes all the way.
Old Oct 17, 2010 | 04:46 PM
Beechkid's Avatar
Beechkid
Assuming all externals are good, then it is the wrong pressure plate and/or throw out bearing
Old Dec 13, 2010 | 10:40 PM
Joefish1943
Thanks for the help. Turns out that the new clutch was the wrong part, he exchanged it and now it works fine.
Keylon
Dec 24, 2015 04:52 PM
wfon
32
Sep 4, 2014 03:57 PM
93Bogger
Jun 4, 2014 05:20 AM
Merlin Miller
15
Jan 30, 2014 08:42 PM
TallPaul
Dec 13, 2010 09:29 AM
