More drama
Old Oct 11, 2010 | 12:00 AM
Waltersboys's Avatar
Waltersboys
More drama
OK earlier today I posted ABS trouble ? no work has been done with that but tonight I drove to a campsite down the road and when it came time to go the EX would not start so we tired to jump it and nothing a little bit of clicking but no starter movement that I could hear,the battery will not take a charge what am I dealing with starter battery alternater.
Old Oct 11, 2010 | 12:59 AM
Monsta's Avatar
Monsta
Sit. Stay.
Did you let the jumping vehicle run a bit to put some charge in the dead battery?
If so, then sounds like you have a connection issue. I mean, obviously you currently have a battery issue but you're loosing battery power somewhere when it's turned off...or so it seems.
Is this the first time it has happened?
Old Oct 11, 2010 | 10:43 AM
Waltersboys
Thanks for the reply This a.m. Iinstalled a new battery and the EX started right up. then I had the guy at NAPA check the charging system he said that it looked good. So its back home with no more issues I hope
Old Oct 11, 2010 | 04:54 PM
cbradford's Avatar
cbradford
Batteries are like that !!!!!!!!!!!!!!
