F-250 Owner Seeks Bump Stop Information
Upgraded suspension bits of the F-250 call for adjustments to the bump stops, but the OP can’t locate them.
Ford Truck Enthusiasts forums member “DieselVol” recently posted a thread in the 1999 to 2016 Super Duty section asking for input on the bump stops for his Ford F-250. He is looking to upgrade the suspension setup and the instructions for the new components state that he has to adjust the bump stops, but his truck doesn’t seem to have any, so he came to the forum for input. Not surprisingly, he got the answer to his question in a hurry.
The Introduction
When the OP first posted his question to the forum, he offered a brief rundown of what he was doing, which led to his needing input on where to locate the bump stops in his truck. The black F-250 shown here is the OP’s profile picture, so we don’t know for sure that this is the truck being modified, but we included a picture here for reference.
“Do the coil spring trucks (2005-2007) have front bump stops? I’m having trouble finding them if they do. I’m thinking about adding a dual steering stabilizer and Superlift says I may need to “slightly limit the compression travel with bump stops”. I assumed I’d need to get taller bump stops. Now I can’t find that the truck has ever them or that anybody makes an aftermarket version that’s taller. Any advice? Thanks.”
The Community Responds
The first person to respond to the initial question was “seville009”, who shared pictures of the bump stop on his 2006 F-350.
They do…..drivers side of my stock 2006 F350….view from both sides of driver side tire
Surprisingly, the OP questioned that information at first.
That looks aftermarket to me. I think I saw one just like it on line. It also looks like it doesn’t have a natural place to bump into. I suspect it’s there because of a problem, rather than stock. I could be wrong.
Leading seville009 to restate some information.
You are wrong. I’m the original owner…..it’s stock as I said. It bumps into the axle if it comes up too much, hence “bump stop”
Upon further inspection, the OP found the spot where his bump stops were originally located, but the rubber portion has fallen away, as shown in the picture below.
Well (hat in hand) I stand corrected! Here’s a picture of where mine used to be. That flat surface just below is it’s landing pad. It’s maybe 6×6” or so, plenty of space to do a good job. There’s another similar one (equally trashed) on the other side. So now that you’ve squared me away (and helped greatly, thanks) the question changes: why is there not a readily available replacement part for this? Nobody I’ve found thus far make any front bump stop for the coil springed trucks. The 99-04 (leaf spring) bump stops are made by several companies. Have I missed something?
While “sxrfun” shared information on aftermarket bump stops that might be just what the OP was hoping to find.
Search for Timbren ses suspension parts…..I use them in the rear of my truck…think they also make them for the front for snowplows etc.
Click here to share information on the bump stops on your own truck, or to ask a related question.
