Watch This Destroyed Ford F-150 Drive Out of a Wreckage!
We’ve all seen the commercial by all the truck manufacturers, where they proudly show their trucks hauling huge piles of concrete, a hundred tree logs, a small building and even an airplane, all with the hopes of convincing customers that their trucks are best and the others suck. Well, about that…
This video posted to Facebook by 4WheelOnline should be the new standard for Ford F-150 marketing and advertising. In what can be described as a war zone, a destroyed 2013 white Ford F-150 sits atop of a pile of wreckage bits, when all of the sudden you can see both the wheels turning as it moves forward and backwards to make its way to the ground.
According to the caption on the video, these are the wreckage leftovers of a collapsed building, and in case you’re wondering, the answer is yes, the building fell on top of the F-150, the very same F-150 that’s now running under its own power, and driving despite it being crushed, broken and basically turned into junk.
Before you bring it up, yes, this is back when the F-150 was built using steel, but that’s irrelevant in this case, because this video highlights the strength of the drivetrain and not the body. So save it.
