Injectors are in!!!
Old 04-07-2006, 01:06 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Thumbs up Injectors are in!!!
This day has turned out to be a good one.
A few days ago my injectors arrived from Beans deisel performance.
I ordered stockers with new, not reconditioned, nozzles and plungers.
I had originally planned to come in this Saturday to install them, but the workload at the shop allowed me to bring the truck in and install them today.
I was planning to take soundbytes of before and after the install but I was way too excited to wait.
11:00 am
I brought the truck in and pulled the valve covers, removed the gaskets and the wiring harness's.
I pulled both rear injectors and let the oil and fuel run down into the cylinder. I thought that just putting a shop towel over the hole would deflect the oil that comes back up through the injector hole. I rolled under the truck and proceeded to turn over the engine by hand and immediatly noticed that the oil came out with enough force to blow the rag out of the way and soak the air conditioner. UGH. (Stuff a ton of rags on top of the air conditioner unit.)
Ok, that hurdle is over; pull the rest of the injectors. Routine job.
The tips of the old injectors didn't appear to be that worn out, but they were sure making a lot of noise during operation.
Remove the oil deflector tubes using a 5mm allen and the 3/8" impact gun.
Install them on the new injectors, leave them a touch loose for the final adjustment later.
Remove all the glow plugs.
Install all the new injectors.
Torque them to 120 inch pounds.
Roll under the truck again and turn over the engine for two complete cycles ( 4 crankshaft revolutions) NO LESS. More if you hear oil spurting out of the glow plug holes.
Position some cardboard over the cylinder heads to deflect any flying oil.
Crank the engine over (no load on the starter with the glow plugs out) to fill the HPOP rail. This requires a couple of minutes total crank times. Don't do it all at once or you'll bake the starter. 30 seconds, go clean up your tools for 5 minutes and then come back and crank for another 30 seconds. Repeat a couple of times.
Remove the cardboard.
Install the glow plugs. I had a full set of Bosch part number 80 033 ( OEM ) glow plugs that I purchaced a couple of weeks ago to install along with the injectors.
Reinstall the valve covers, boost tubes, reconnect whatever sensors, connectors that were removed to gain access.
4:00 PM
I cranked on the starter for about 15 seconds and it fired with a big cloud of smoke.
I am immediatly struck with how much healthier the idle sounds. A deeper tone, more even, not a bit quieter. So crisp, so clean. There is NO SUBSTITUTE for new injector nozzles. Sounds like a BRAND NEW engine.
Driving around it's smooth, quiet, powerful, all the hammering is gone.
And the amount of throttle required to maintain speed is cut in half. I am positive that my lost mileage is coming back.
Underway the engine is so much quieter that I strain to hear the diesel noise over my 5" cannon, all four windows down.
I am completly satisfied with the fruit of my labors, starting with the Hutch mod, and removing the quick connects, the oriface mod to completly remove the air from the fuel rails and now the final addition: putting in the fuel injectors.
Life is good.
Old 04-07-2006, 01:17 AM
mech2161's Avatar
mech2161
mech2161 is offline
Good deal!
Old 04-07-2006, 01:21 AM
Kwikkordead
Kevin you are either up VERY early or VERY late.
Old 04-07-2006, 01:24 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Originally Posted by Kwikkordead
Life is good.
Yup! Say it again!
You're just about ready for summer now, aren't you?
Pop
Old 04-07-2006, 01:28 AM
clem1226's Avatar
clem1226
clem1226 is offline
Thumbs up
Congrats Kwik, Nothing like the satisfaction of a job well done.
Old 04-07-2006, 07:48 AM
mueckster's Avatar
mueckster
mueckster is offline
I like your description of the injector replacement process. I copied and saved it for future reference. Thanks for sharing. Good job!
Old 04-07-2006, 09:57 AM
guzzle92's Avatar
guzzle92
guzzle92 is offline
Nice write-up Kwik. I'll be saving it for future reference (hopefully in 50K miles or more ) It's good to hear that they made a tremendous difference.
Old 04-07-2006, 10:23 AM
trakman's Avatar
trakman
trakman is offline
Question How many?
So Kwik....how many miles did you have on the used injectors. Really made that much difference, huh?
Old 04-07-2006, 10:32 AM
Kwikkordead
69,000 miles. About 55,000 of those were sucking foamy fuel until I did the Hutch and other mods to the fuel delivery system on my truck.
The engine would rock when the fast idle would activate in the morning and sound like it was running on 7 & 1/2 cylinders. Underway it would sound like a rod was trying to knock. It was getting loud enough to make me feather the throttle and drive around at 2500 rpm. At 2000 it was hammer hammer hammer. And the mileage was taking a nose dive.
I haven't had a chance to drive all the air out of the HPOP rails yet. Only got about 15 miles so far. But it is a VAST improvement over what it was doing before. I'm looking forward to vacation next month pulling the trailer.
Old 04-07-2006, 10:38 AM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
Awesome job, Dan! It's great to hear that all went smoothly and they made such a big difference for you truck.
Old 04-07-2006, 10:55 AM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
Great info Kwik.. do you need to use any "special" tools to do the job?
Old 04-07-2006, 11:34 AM
jtharvey's Avatar
jtharvey
jtharvey is offline
Nice writeup. Good to hear that injectors can make that much of a difference. I'd expect it to be purring like a little kitten once you've gotten all the air purged out of the HPOP rails. Maybe time for a little evening drive after work today?
Old 04-07-2006, 11:57 AM
RobertJohn's Avatar
RobertJohn
RobertJohn is offline
Nice work Kwik...
I'm having mine scanned next week to see if my injectors are bad, I'm hoping I don't have to replace them all, it's the $$$$.
I've done a search for the Hutch Mod and can/t find it.
Any ideas on which thread it is ????
Old 04-07-2006, 01:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
I believe this might help.
BTW, congrats KWIKK. Good writeup.
Old 04-07-2006, 01:27 PM
Batgeek's Avatar
Batgeek
Batgeek is offline
I've seen those instuctions before on their site, but could not find the in tank and pre-pump kit listed for sale anywhere on their web site. Is it an over the phone item or have they discontinued it?
Quick Reply: Injectors are in!!!
