Dana 60 and Dana 70HD axle swap
Old 03-26-2017, 07:43 PM
Carmax's Avatar
Carmax
Carmax is offline
Ok guys ive asked different questions and gotten answers ahere and there but i need them all condensed. I want to swap my 65 F350 Dana 70HD dually axle, into my 65 F100 with a current Dana 60 under her. My questions are:
1. Fitment issues- the frames should be the same width but the 70 center section is longer would moving the acle back an inch on the f100 leafsprings be ok? As well as will the F100 leafs support the swap? I dont plan on hauling just want a badass truck.
2. Will pinion yoke from Dana 70 bolt up to F100 driveshaft/u-joint? Is it possible to swap the yokes from the axles?
3. I am looking into swapping ring and pinion from 4.56 gears to a 3.54 set and doing a master rebuild. Im currently working on brakes right now. How hard is the rebuild and what are some things to look out for?
4. If anybody has any advice outside of the questions ask please share it. This will be my first swap to do.
Old 03-26-2017, 10:07 PM
MN66's Avatar
MN66
MN66 is offline
Not sure on the other fitment issues, but I believe the the D60 has a carrier split of 4.56 and up and 4.10 and down. You'd need a 4.10 and down carrier in order to use 3.54 gears.
Update:
I noticed you're wanting to use a D70, not D60. I'm not certain if the same split exists for the D70.
Old 03-26-2017, 10:28 PM
Carmax's Avatar
Carmax
Carmax is offline
From everything ive read it is the same and from the picture i have its 4.56 or higher its hard to make out and i was in a rush. What what i gather was the bigger carrier was narrower narrower and some companies make a thicker ring gear to compensate. I need further verication id like to go faster than 45mph if im lucky. Or to swap carriers which one would work best?
Old 03-28-2017, 12:50 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Your 1965 F100 does not have a Dana 60 unless it was swapped in. Dana 60's were only installed in F250's that use 8 lug wheels on a 6.50" bolt circle.
It either has an optional Dana 44 or a Dana 60.2, both use 5 lug wheels on a 5.50" bolt circle.
The Dana 70 from a 1965 F350 has 6 lug wheels on a 7.25" bolt circle and FoMoCo did not offer a pickup with DRW until 1980.
1965 F350 Dana 70 ratios: 4.88-1; 5.13-1; 5.87-1.
The companion flange of the 70 is not the same as a Dana 60 or a 60.2 nor a Dana 44.
Old 03-28-2017, 01:17 PM
Carmax's Avatar
Carmax
Carmax is offline
thanks numberdummy for ruining dreams haha. I had just found out that the 70 would not be able to except a lower gear for cruising speed so even if it could made out to the truck itself I couldn't get it to work for my application. I also believe that the Dana 60 in my F100 is a swap I don't have the truck in front of me but I believe it does have the eight lug wheel pattern as well as the front. So now with my dreams crushed I will just go back to my original plan of using my foot 9 inch
Biggie
1999 to 2016 Super Duty
02-06-2020 12:33 AM
kindorotten
05-31-2016 10:28 PM
mattjensen
18
02-02-2009 11:18 PM
newpy383
01-31-2004 06:38 AM
Megalomaniac
05-23-2003 07:27 PM
Quick Reply: Dana 60 and Dana 70HD axle swap
