Can you reach these/replace these without removing the heads? This may be a dumb question because I do not think that you have to, but I have never done it, thus the question.
Unless you are asking what type of "gas" you need for a 6.0, like I said last week there are very few dumb questions.
That said, there is a ton of info in the sticky folders and elsewhere using the search feature. ......
Thanks, and yes, I have been reading like crazy in the sticky folders, but the amount of information is overwhelming. Sometimes I need to take a break, and just ask, thanks for understanding.
The bag on the right is your standpipe and dummy plugs. The long ones will split at the top for easy install. Just lube them up with clean oil like a lot of clean oil you don't want to roll the orings or knick them when inserted.
