DPF delete programer question
OK I think I have a good one for you guys.
My ride is an 08 f250 6.4L King ranch 4x4. I bought it with 150K on it and really don't drive it much. I pull a good bit when I do drive it, but in 2yrs it has only seem 20K miles. Most of the time I am on my KLR. BUT yesterday, changing the oil and fuel filters, right after I smacked my head on the exhaust, I noticed I have a stainless straight pipe. No DPF. The. Truck has no tuner, and no in-lne OBDII tuner. And thinking about it, I have never seen the Regen light. The cel does work, so the bulb has not been pulled. The only mod I can see anywhere that looks at all suspicious is there is a bung at the beginning of the tail pipe, right after the bolts for the header /tailpipe that has what looks like a mini O2 sensor. The wire for it has appx 24" of wire coiled up and zip tied. I am thinking that originally went to the dpf.
Any thoughts? I am planning on an EGR delete and I don't want to run into "compatibility"problems. This will happen soon as I am fixing to do valve cover gaskets and I want to do it while all the other crap is out-of-the-way .
Just because there is no physical tuner does not mean the truck is not tuned. I'm betting it's tuned by the last owner, but they kept the tuner and left you with a tuned truck. The sensor possibly EGT probe that may have connected to the tuner the last owner had installed? Would need a pic to confirm that though.
Can you tell me if the mini max can do the same thing for the EGR. I don't want to have a permanent tuner. The idea of just uploading the tune and removing the unit is very appealing to me.
Enjoy your "off road race tuck". Aspiring new sport!
Well after some looking. The EGR pipe is still physically in place and gets quite hot. So I am guessing that the D.F. did not disable the EGR when he disabled the DPF. So I either got to spend $700 on a one time use tuner or "DOES ANYBODY WITH A MINI MAXXLIVE NEAR AUGUSTA GA?"
Travis Counts
1999 to 2016 Super Duty
04-13-2018 04:03 PM
