1997 460 heads
Old 02-24-2017, 12:21 PM
hambone460's Avatar
hambone460
hambone460 is offline
1997 460 heads
hi there, i am new to the forums here. i have a 1997 f250 hd 4x4 with a 460, and i want to get more power out of it. right now i have hedman headers, dual 3" pipes and flowmaster super 10s, i made a new (intake horn thing??) out of aluminum that is straight through, and im running autolite double platinum plugs with 9 mm plug wires, accel coil and msd cap and rotor. which set of aftermaRKET HEADS WOULD GIVE ME THE MOST POWER FOR MY MONEY AND WOULD BOLT RIGHT ON WITHOUT CHANGING ANYTHING ELSE? THANKS
Old 02-24-2017, 12:27 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
Short answer: None
Welcome to FTE
Old 02-24-2017, 12:58 PM
rla2005's Avatar
rla2005
Some good reading here from a forum member who ports heads for a living: https://www.ford-trucks.com/forums/9...ts-are-in.html
Old 02-24-2017, 03:18 PM
hambone460's Avatar
hambone460
So is there anything I can do to this fuelie pig to get more power? I already have the basics covered, headers, exhaust, and modified intake horn. What can I do to see better power? Preferably without gobs of money?
Old 02-24-2017, 03:26 PM
rla2005's Avatar
rla2005
https://www.ford-trucks.com/forums/97...ts-are-in.html
Or find a used Vortech supercharger kit.
I assume you are no longer using the factory torpedo converter?
As stated you have the basics covered pretty well. You could net a few more ponies by bumping the base timing up a few degrees. Beyond that it's going to take some cash.
Old 02-24-2017, 03:37 PM
hambone460's Avatar
hambone460
Which heads can I run on it that will get more power? Or will I have to get new pistons and stuff too.
Old 02-24-2017, 04:11 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
DeathRangerofDeath is offline
There are no aftermarket efi heads. None. Zero. Zilcho. Your only options are porting your stockers, having stockers ported, you going to carb heads and getting intake adaptors to work to try and keep the efi intake.
Old 02-24-2017, 04:59 PM
hambone460's Avatar
hambone460
So what should I do? I would like to see around 400 horsepower out of it, and be a daily driver. It is my daily, but I'm buying an econobeater so I can work on this. Aside from money, what should I do? Convert to carbs? Stroke it? What have y'all done?
Old 02-24-2017, 05:04 PM
rla2005's Avatar
rla2005
Read the thread on the link I posted. Boport ended up with ~300+ RWHP which is roughly 400 crankshaft HP. This was normally aspirated, factory cam and headers. The engine was lean up top so I suspect the fuel system was maxed out.
Going carb. is expensive too. You can't just bolt on an intake and go. The ports on the EFI heads are different.
If you have an E4OD transmission then you need to figure out how to run it. It's 100% electronic controlled.
Stroking is an option but you still have the same bottleneck exhaust port heads.
Old 02-24-2017, 06:58 PM
DeathRangerofDeath
My personal plan of attack is going to be to go to carb heads, carb intake setup for injectors, and a 4bbl style throttle body in place of the carb(or 90* elbow off the intake and a stanard oem style throttle body) , then switch over to either an a9l sefi setup or go aftermarket both with a stand alone e4od computer.
But I haven't even started, mine still runs too good to want to tear into it.
BigBlocker0248
06-29-2015 10:35 AM
gschembs
09-07-2013 04:26 AM
Myfreeford
11-10-2010 08:14 AM
Jerryz
09-19-2003 02:48 PM
Quick Reply: 1997 460 heads
