Antifreeze smell
Antifreeze smell
Anyone else have an antifreeze smell around their truck? Every now and then I get a whiff of it when I park in the garage and walk by the right front wheel. Today, it was 60 degrees (the warmest it has been since I got the truck), and I did a lot of in town driving and smelled it while driving around (had the windows down).
I looked around the engine compartment and under the truck and don't see any leaking. The overflow tank still measures full. Just curious if any of you have experienced this or have any ideas. Thanks.
I experienced this with my 2013 Cadillac CTS-V Coupe. No sign of coolant leak and the overflow tank was full. When I would park in the garage after a 30-60min drive there was a very potent smell of coolant and It ended up being a blown head gasket which they covered warranty. The dealer mentioned the one head was not torqued down to spec and it broke the gasket in one area causing cool and to leak into the piston cylinder. Not sure if this is your issue or not, but just something to think about.
There was a post on the "things you don't like" thread:
https://www.ford-trucks.com/forums/1...l#post16914087
Positive. I had a 2013 Duramax before this truck and I know what the "strange" emissions crap smells are like. Best way to describe this smell is that it's similar to maple syrup.
The smell is is not as strong as posted above. It does not fill my garage. Just catch a whiff of it when walking by the front. Seemed a little stronger today.
My truck sits in a garage. So I hear you on the smells. Strangely' no diesel smell, but smell urea, smell hot exhaust, smell brake a bit, all new break in stuff I hope. I have checked up unserneath a few times, can't find a thing wrong. Checked oil ,transmission, both coolant same level. I think you just keep watching the two coolant tank levels. Also check the pass side of transmission for the cooler lines going in and out to be sure no leaks.
I had this happen on my 2009 Hyundai Sonota. After replacing a windshield that had been cracked for a couple of months, the fogging I had attributed to the crack did not stop. It was then that I put together the transitory odor I was smelling after parking in the garage and the windshield fogging and found that the hoses going into and out of the heater core had failed and were leaking onto the firewall. The leak was not severe enough to cause a noticeable drop in the radiator fluid level.
