Can I lay can on it's back
Old 01-19-2017, 02:44 PM
armyaviation's Avatar
armyaviation
armyaviation is offline
i'm working on 56 and I was wondering if I could unbolt the cab from the frame and roll it onto its back on some padding to work on the bottom of the cab. I have the bed removed and it would be easy to do I was just wondering if anyone has thoughts on the structural integrity of the cab laying on its back.
Also looking for a Cowl vent brace and handle for 56 if anyone has one for sale let me know
Old 01-19-2017, 02:51 PM
schoo's Avatar
schoo
schoo is offline
I did on both my 49 and my 64
64cab rust 007
the 49 I rolled it on its back a lot when installing the engine/tranny while the cab was on the frame
sometimes I put carpet under other time I put a tire just depended on what I was doing when welding be careful for fire
Old 01-19-2017, 03:48 PM
Harrier's Avatar
Harrier
Harrier is offline
It's very helpful in cleaning and painting the underside of the cab
Old 01-19-2017, 04:24 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
I do it all the time. Many times when I just want to get a better angle on the lower firewall I will tilt the cab back and let the upper edge of the rear window opening rest on a barrel or sawhorse.
Old 01-19-2017, 05:08 PM
Cougar54's Avatar
Cougar54
Cougar54 is offline
I rolled my cab on the back as well as the sides.
Old 01-19-2017, 06:59 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
Yup, that's what I do on my 49. Makes working on the underneath of the cab a lot easier.
Old 01-20-2017, 09:17 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Didn't realize you took a picture of our handy work that day.
Old 01-20-2017, 09:36 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Just in case all the other pictures weren't enough:
Old 01-20-2017, 09:55 AM
Harrier's Avatar
Harrier
Harrier is offline
I didn't post the picture of grinding away at the rust.
Harrier's Avatar
Harrier
Harrier is offline
There are never enough pictures.
Old 01-20-2017, 04:19 PM
EAK69's Avatar
EAK69
EAK69 is offline
Same with me! I made sure I put some thick blankets down before I laid it on it's back and had no problems......
Old 01-20-2017, 04:39 PM
schoo's Avatar
schoo
schoo is offline
earl did you tack weld the doors? I have read where guys do after setting the margins then fix cowl or floor, I see a brace inside the cab though
Old 01-20-2017, 05:14 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Can you lay your cab on its back?
Yes, just don't do it like this guy!
Old 01-20-2017, 05:28 PM
DR Smith's Avatar
DR Smith
DR Smith is offline
if cowl vent handle and brace are same as 53 I think I have them on my parts truck
Old 01-20-2017, 09:29 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,132 Likes on 2,656 Posts
Is this the piece you are looking for?
http://midfifty.com/item.php?INV_ID=...ace-under-dash
Quick Reply: Can I lay can on it's back
