Level it the right way!
I've read through a few different posts about leveling the new super duty's and wanted to put together a thread that we can read with the correct information. Please post your insight and what you have learned to be accurate from your own level experience. Since 2" level seems to be the most popular, lets base the answers off of that height increase unless noted differently. Please add anything I missed.
A couple questions I want to address:
1) what are the major differences between the kits and quality? What makes one better than the other?
2) Are track bar relocation brackets needed to keep the oem specs in tact and axle centered? What is a good brand?
3) Are castor bushings needed to keep oem angle? Ruth utter recommended Duralast bushing 11260 that worked on the prior years trucks as well. Is this correct?
4) Are new shocks required for a level? I'm not sure on the stock travel length but I would think they would be ok to keep for average uses.
I've been doing a lot of research on this topic also for the 250 I'm ordering soon.
Spoke to BDS tech guy earlier this week regarding their 2" kit with 4 Fox shocks and he offered the following info:
Track bar bracket-BDS is currently developing one that will be included in their 2" kit, I was told this will be available "very soon". In the meantime, they directed me to Readylift or ProComp (I've confirmed part numbers with both of them also) if I simply wanted to purchase the bracket alone to install with their kit. The 2" BDS kit will result in the front axle being slightly off center.
Castor bushings-again in reference to the BDS 2", they stated specifically that the ball joint alignment cams they include in their kit are not "required" necessarily on less that 2.5" of level, but that the trucks steer and drive noticeably better with the included ball joint alignment cams installed after leveling. Castor bushings, per BDS, should not be needed with their kit in addition.
Shocks-extension brackets at a minimum are needed for 2" kits and 2.5". The BDS has the option of buying longer replacement shocks. Based on the positive feedback I've read here and elsewhere about Fox in conjunction with leveling, that's what I will do.
This could be true that they are the same parts, I'm not sure. I'm not the most knowledgeable when it comes to the various different front end parts that are responsible for correct geometry/alignment.
Track bar relocation brackets
Procomp: part number 62687 (a fellow member here advised that he used this on his 2017 after BDS 2" install and it did re-center his front axle)
Ready lift: part number 67-2538 (this is the part BDS themselves advised I could use if their relocation bracket wasn't out yet)
Edit: never mind I see you referenced the ready lift in a previous post. $500 isn't too bad for the install with alignment at a dealer, sounds about normal. I had a similar kit installed on my 2500 Ram and paid around 375-$400 at my local privately owned tire shop.
I don't disagree! Any chance you could measure the heights with it hooked up and know the pin weight of that? What I'm personally looking for is that imy truck will be leveled with about 1k lbs or so in the bed.
