cowl seal
Old 12-09-2016, 02:38 PM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
cowl seal
At the risk of exposing my stupidity, which way does the cowl to hood seal go, lip up or down?
Old 12-09-2016, 03:15 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
No worries... I left remnants of my old one during disassembly and then took a pic for reference!
Lip is on top.. like a "7" in profile.
Old 12-09-2016, 05:11 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
I wonder if the clips line up only one way? Maybe that's why some folks say they fit and others say the clips are in the wrong spot. Sounds like something Ford would have done to make sure it gets mounted correctly.
Old 12-09-2016, 05:49 PM
GaryKip's Avatar
GaryKip
GaryKip is offline
yea, how hard would it be to print "This side up" somewhere along the length? But then we would have to be able to read Chinese too!
Old 12-09-2016, 07:24 PM
justcruzin's Avatar
justcruzin
justcruzin is offline
That wasn't the case for mine. I tried it both way's, clips were off either way I had it.
Old 12-09-2016, 07:27 PM
mrpotatohead
Yeah, I tried mine both ways and no they wouldn't line up either way. For the record, this one has two clips that still don't line up so i'll have to remove and reinstall them correctly.
Old 12-10-2016, 08:44 AM
orich's Avatar
orich
orich is offline
I've replaced mine two times since owning my 71 truck an notice when ordering it by yr select.
Never had any problems with the clips lining up lip down. If lip was up it would fill with leaves & crap.
With lip down any debris will fall into engine bay or to the ground.
Orich
Old 12-11-2016, 11:32 AM
mrpotatohead
Finally found undisputable evidence of the correct way to mount it.
Old 12-11-2016, 02:36 PM
hot-rod's Avatar
hot-rod
hot-rod is offline
I ordered my at LMC. NO clip has fit And the seal is too rigid.
Old 12-11-2016, 03:38 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by mrpotatohead
Finally found undisputable evidence of the ]
Wasn't that way on my unmolested 70...
My one-owner 71 F250.. the lip is gone but one can readily see where it was torn away...
What ever works for you I guess...
Old 12-11-2016, 03:56 PM
mrpotatohead
Well I'm really confuse now. That picture I posted was supposedly from a 71 Ranger with 315 miles on it. It was from the Fordification website. I'll guess I'll flip a coin at this point.
Old 12-11-2016, 09:50 PM
orich's Avatar
orich
orich is offline
No confusion here think about it.
The hood folds down on it that why in your picture the lip is folded downwards proves it's upside down. An would drop leaves an bird poop into it to the point it would have to be cleaned out.
Orich
Old 06-20-2022, 01:58 AM
amullins74's Avatar
amullins74
amullins74 is offline
5th Gear
The whole deal
Anyone know where I can find that cowl panel?
Old 06-20-2022, 11:10 AM
RTT's Avatar
RTT
RTT is offline
Question
I tried to install a new one, when I pulled it away the clips would fall behind the firewall down into the cowl area with no way I have thought of yet to be able to retrieve. Have you guys had this problem.........???
steve340
09-03-2014 07:01 PM
Speedjester
08-26-2010 10:18 PM
biggut
06-27-2009 06:30 PM
blakeusa
11-30-2007 11:53 AM
Quick Reply: cowl seal
