Do i need brakes?
Old 12-07-2016, 06:25 PM
David Maloof's Avatar
David Maloof
David Maloof is offline
Do i need brakes?
Howdy folks..i am new here..i am having a rough time and could use some help. i have a 73 f100 4x4 with a 352. replacing front brakes 11x2 drums. the new hardware kit doesnt come with the shoe to shoe return spring. i cannot find it anywhere. do i need it? where doni find it? thank you in advance
Old 12-07-2016, 07:06 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Welcome to FTE! There are lots of great people here that are willing to answer just about any question. Repeatedly...
Anyway, I think that spring is required. Seems to me that the kit is short...
Old 12-07-2016, 07:43 PM
David Maloof
Kit
I thought it was too but i have checked 3 other parts stores and their kits are all the same.
Old 12-07-2016, 07:48 PM
PapaBearYuma
This is the kit at o'reilly
Old 12-07-2016, 09:02 PM
David Maloof
Thats what i have..this is a pic of the spring i need.
Old 12-08-2016, 12:00 AM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
The kit in the pic should be the one for 11" brakes. The spring you have appears to be from an F250 12" rear brake. How it got onto your truck is ?. Btw, the engine in your truck would be a 360. The last year for the 352 was 1967.
Old 12-08-2016, 08:26 PM
David Maloof
I will measure them again but i believe it was 11x2 brakes. the motor at some point got swapped out. the stamp on the block says its a 352. the spring i am looking for measure 7 3/4 in rom hook to hook
Old 12-08-2016, 10:08 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
They ALL say that. Its 99% a 360
Old 12-09-2016, 05:27 AM
David Maloof
i did not know that. thank you
Old 12-09-2016, 08:46 AM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
The Ford mpc DOES show a shoe-to-shoe return spring. (2) are included in kit # D9AZ-2A225-A. Green Sales shows 15 in stock. Call them and see if it is what you are looking for. This number does not cross into any aftermarket part. Green Sales Co. 1-800-543-4959
Old 12-09-2016, 05:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is the wrong part number, it's for misc. cars with 10" brakes. There is a D9AZ-2A225-B kit, but...
It's not correct for 1973/75 F100 4WD's with 11" x 2" front brakes, as the primary brake return spring is wrong.
It's only correct for 1973/75 E200's with front drum brakes and the 11" x 2 1/4" rear brakes of 1973/79 E100/150 & F100/150 & Bronco.
B5A-2035-A .. Primary Brake Return Spring - color coded blue / Obsolete ~ Available NOS & from auto parts stores.
1959/63 F100 2WD/4WD (front/rear) / 1964/75 F100 4WD (front) / 1955/59 Ford Passenger Cars / 1955/60 Thunderbird.
C0MM-2035-A .. Secondary Brake Return Spring - color coded black / Available NOS & from auto parts stores.
1967/75 F100 4WD (front) / Misc: 1960/72 Passenger Cars.
C3AZ-2035-A .. Brake Return Spring (shoe to shoe) - color coded red / Obsolete ~ Available from auto parts stores.
1966/75 F100 4WD (front) / Misc: 1963/79 Passenger Cars.
If y'all want the sources for B5A-2035-A (Green Sales only has 1) and C0MM-2035-A .. I'll list them.
No Ford dealer or obsolete parts vendor has C3AZ-2035-A
Old 12-10-2016, 12:34 AM
bryanmartin's Avatar
bryanmartin
bryanmartin is offline
Do i need brakes?
Yes. Yes you do.
Old 12-11-2016, 10:36 PM
Jonnyuma's Avatar
Jonnyuma
Jonnyuma is offline
Originally Posted by bryanmartin
Yes. Yes you do.
Sometimes, on side jobs, I drive an older-than-dirt itself Kenworth dump truck with no front brakes...apparently they were optional in the 70s...? Luckily it doesn't really go too fast either.
TomsBeast
28
05-14-2020 10:02 AM
artscott61
17
08-25-2017 11:20 AM
Macs1964F100
03-23-2014 07:28 PM
SuperDuty93
08-19-2013 06:19 PM
packrat56
09-10-2007 08:27 AM
Quick Reply: Do i need brakes?
