1986 F150 Power Brake Booster
I picked up a re-manufactured Wearever Unloaded Vacuum Power Brake Booster from advancedauto today to fix a horrible vacuum leak. I got it installed tonight, and have a question.
Wearever Brake Boosters Vacuum Power Brake Booster without Master Cylinder - Remanufactured 54-74211: Advance Auto Parts
The connecting rod on the new power booster is about 20 thousands larger than the original booster rod in one direction (.65 inches on the new rod and .63 inches on the old connecting rod). It seems to be slightly wallowed out like the previous owner may have not had a bushing on the break. I assume I need to see if I can find a bushing to take up some of the slack.
When you press on the break pedal, I hear a slight click sound. I have determined it sounds if the click is coming from inside the booster and not from the switch or the slack in the connecting arm. It made a loud pop when I pushed the pedal in for the first time after instillation. Now it makes a little click sound every time I push the pedal in.
Should I find a bushing to take up some of the slack form the connecting rod and forget about the noise, or should I take it back and get a replacement?
It seems to be working fine and does not leak.
Also, what bushing should I get if any?
Thanks,
Cody
Thanks,
Cody
Cody,
This bushing would go where?
Between firewall & booster or booster & master or the pin the rod fits over at the pedal?
Just cant picture where you want this bushing is all. Then again stock I don't think used any bushings.
Think you can adjust the rod longer/shorter between the booster and master but that is all.
Dave ----
Dave ----
Here are the washers.
Ford - Ford - Ford Brake Light Switch Bushing - Mounts Either Side Of Brake Light Switch - Genuine Ford | C5DZ-2B129-A - Macs Auto Parts
Keep looking, especially at old mustang and other ford vehicle restoration places. Ford used this setup since the 60's.
OK so you don't have the black bushing and want to make one right?
I am sure the pin thru the rod has some play or the brake light switch would not work.
If your setup had all the plastic washers & bushings then I would say that is good.
Now where did you say this clicking was coming from?
Was it from inside the booster and if so I would get another.
Dave ----
Dave ----
That is what I was thinking, but I did not know if anyone else experienced the same issue. I will call and get a replacement.
Thank you guys for your input!
Thanks,
Cody
Overall very very happy.
in hindsight, I should have just returned the first unit be for even installing it.
Thanks,
Cody
Neither one of the boosters I got hat any sort of tag on them. The first one came with a loose pushrod out of the box.
