Another E4OD/FIPL question
Just bought my first diesel. 1993 7.3 non turbo. Started driving it home and the overdrive off started flashing. Pulled the codes and only got the 62. Started at the FIPL and shot the wires per the threads on this and pretty much every other site. My issue is that I'm getting the 5v on the black and white wire and 15 ohms for ground from the orange and white wire. From the posts, this is exactly backwards from what it should be. I don't see anything at the transmission as far as wires being spliced. The voltage is 1.2 idle and 4.2 wot from the center wire still. I searched and couldn't find any threads on this and I'm sure that it's the wires are swapped some how but was hoping for some insight.
on
I don't know much about the E4OD other than the parts it's connected to in order for it to work and I don't have a service manual nor schematics that cover an E4OD.
I've seen that symptom mentioned before.
Are you sure that is a TPS related symptom?
Sounds like maybe some confusion about using the meter and taking the readings properly rather than reversed wires but I really don't know enough about it. I just read the first page of the following topic, (too tired to read the rest) and that's what I will refer you to in case you haven't read this one yet:
Includes in the opening post, UPDATED: A/T - E40D FIPL Sensor Trouble Shooting & Adjustment
TECHNICAL BULLETIN # 186A
DATE: Jan 1994
Posted on 12-03-2011, 06:30 PM
https://www.ford-trucks.com/forums/1...ions-only.html
EDIT to ADD: On the last page of that thread which is currently Page 4, Chevy_Eater posted a link to download a .ZIP file of E4OD Information which should be very useful to anyone working with an E4OD
DATE: Jan 1994
Msword
02-23-2022 12:31 AM
RRE101
06-14-2010 07:57 PM
hans88
01-04-2006 03:30 PM
Broncobirdy
1978 - 1996 Big Bronco
08-25-2005 08:26 PM
