HPOP trends
HPOP trends
Just dropped coin on a HPOP replacement on my 2006 F-350. Coming home to Texas from CO pulling my 5th wheel. Everything seemed fine until we finished lunch and tried starting in Wichita Falls. Crank, no start. FICM and sync were good. Not producing pressure. STC fitting not leaking.
My truck just surpassed 153,000 miles.
Wondering what is the typical life of HPOP on these 6.0's...
I interrogated the shop owner...he was very knowledgeable on the 6.0's. He said they checked the STC and piping for leak to verify it was indeed the HPOP (after eliminating other possibilities). I could only verify I was not building pressure when cranking.
I was surprised it would fail so suddenly, but in thinking back on pulling up Raton Pass, I thought she was ******* on me some.
Another good talk with shop owner in Wichita Falls...really knows his stuff and has solid reputation.
In addition to HPOP, they replaced: STC fitting, tubes, dummy plugs and IPR valve. Filled with Rotella T.
Now notice extended crank when cold with successful start (didn't have that issue before HPOP went out).
Motorcraft 650 batteries nearing 3 years. I was going to have them tested. Also preparing to do battery ground mod.
Any other suggestions to resolve cold extended crank?
Don't think so...I talked with mechanic who did work. No other issues noted, IPR screen intact, compliments on how well the truck maintained .
Extended crank/start only on first cold start attempt. All others normal start (i.e. I start it with extended crank, shut down and restart). Warm starts not an issue.
Just started after 3 day sit in Texas...after watching video I see that IPR% jumps to 85% after cranking, with ICP sitting low. ICP on SGII doesn't jump up >500 psi until after it has started.
https://dl.dropboxusercontent.com/u/...G_1504.MOV.m4v
