Torque Pro Ford 6.7L Extended PIDs
I thought I would start a new Thread with a list of Ford 6.7L Extended PIDs that I think are working good enough to be useful to some but maybe not all. If anyone has any PIDs that they would like to add to the list, please post on this thread and I will try to keep the list up to date on the first post of this thread. I’m also still testing about 30 PIDs. If you find any errors please let me know and I’ll edit in the corrections
[/center]
Torque Pro 2013 Ford 6.7L Extended PIDS<O</O< font>
Updated. July 09, 2014<O</O>
<O</O< p>Ambient Air Temperature in °C (Truck External Sensor) – <O</O< font>
PID – 22F446 – Done Testing - <O</O< font>
Long Name (used in menus) – Ambient Air Temperature C 6.7L<O</O< font>
Short Name (used in gauge display) – Air Temp<O</O< font>
Min Value – 0.0<O</O< font>
Max Value – 100<O</O< font>
Scale Factor – x1<O</O< font>
Unit Type – (NOTE: Leave blank, I have my units set to “F” so this will show “C”)<O</O< font>
Equation – A-40<O</O< font>
OBD Header –
<O</O< font>
<O</O< font>
Ambient Air Temperature in °F (Truck External Sensor) –<O</O< font>
PID – 22F446 – Done Testing<O</O< font>
Long Name (used in menus) – Ambient Air Temperature 6.7L<O</O< font>
Short Name (used in gauge display) – Air Temp<O></O>
Unit Type – °F<O</O< font>
Equation – A*(9/5)-40<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
Accelerator Pedal Position “E” –<O</O< font>
PID – 4a – Done Testing – Custom PID<O</O< font>
Long Name (used in menus) – Accelerator Pedal Position E 6.7L<O</O< font>
Short Name (used in gauge display) – APP E 6.7L<O</O< font>
Unit Type – %<O</O< font>
Equation – (A-20)*1.22<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
Barometric Pressure (from Torque App) –<O</O< font>
PID – 33 – Done Testing – Torque App PID<O</O< font>
Long Name (used in menus) – Barometric Pressure (from Vehicle via Torque App) 6.7L<O</O< font>
Short Name (used in gauge display) – Baro<O</O< font>
Unit Type – psi<O</O< font>
Equation – <O</O< font>
OBD Header –
<O</O< font>
<O</O< font>
Boost (Turbo) – Boost -<O</O< font>
PID – 0187 – Done Testing<O</O< font>
Long Name (used in menus) – Boost 6.7L<O</O< font>
Short Name (used in gauge display) – Boost<O</O< font>
Max Value – 40.0<O</O< font>
Equation – ((((B*256)+C)*0.00393)+2.25)-Baro()<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
DPF Regeneration Status – <O</O< font>
PID – 22F48B – Done Testing.<O</O< font>
Long Name (used in menus) – DPF Regen Status 6.7L<O</O< font>
Short Name (used in gauge display) – Regen<O</O< font>
Max Value – 100.0<O</O< font>
Unit Type – ON/OFF<O</O< font>
Equation – {B:0}<O</O< font>
OBD Header – 7E0<O</O< font>
<O</O< font>
DPF Distance Since Last Complete Regen –<O</O< font>
PID – 220434 – Done Testing<O</O< font>
Long Name (used in menus) – Distance Since Last Complete Regeneration 6.7L<O</O< font>
Short Name (used in gauge display) – DSLR (DIA)<O</O< font>
Unit Type – Miles<O</O>
Equation – ((A < 16)+(B < 8)+C)*0.24<O</O< font>
Comment : No spaces in equation, only way it would let me post it was with spaces??<O</O< font>
<O</O< font>
DPF Pressure –<O</O< font>
PID – 22116C – Still Testing -<O</O< font>
Long Name (used in menus) – Diesel Particulate Filter 6.7L<O</O< font>
Short Name (used in gauge display) – DPFP<O</O< font>
Equation –<O</O< font>
<O</O< font>
DPF Soot Mass % –<O</O< font>
PID – 22042C – Done Testing – From other member<O</O< font>
Long Name (used in menus) – DPF Soot Mass % 6.7L<O</O< font>
Short Name (used in gauge display) – Soot %<O</O< font>
Equation – ((((A*256)+B)*(100/65535))-1)/1.75*100<O</O< font>
<O</O< font>
DPF Soot Mass –<O</O< font>
PID – 22042C – Done Testing – Data Value (1.7 = 100% Soot?<O</O< font>
Long Name (used in menus) – DPF Soot Mass 6.7L<O</O< font>
Short Name (used in gauge display) – Soot<O</O< font>
Min Value – 1.0<O</O< font>
Max Value – 3.0<O</O< font>
Unit Type – Grams/Liter<O</O< font>
Equation – ((A*256)+B)*(100/65535)-1<O</O< font>
<O</O< font>
EGT Post Turbo – EGT 11 –<O</O< font>
PID – 22F478 – Done Testing<O</O< font>
Long Name (used in menus) – Exhaust Gas Temperature Sensor Post Turbo EGT 11 6.7L<O</O< font>
Short Name (used in gauge display) – EGT 11<O</O< font>
Equation – (((B*256)+C)*0.18)-40.0<O</O< font>
<O</O< font>
EGT Post SCR/Pre DPF – EGT 12 –<O</O< font>
Long Name (used in menus) – Exhaust Gas Temperature Sensor Post SCR/Pre DPF – EGT 12 6.7L<O</O< font>
Short Name (used in gauge display) – EGT 12<O</O< font>
Equation – (((D*256)+E)*0.18)-40.0<O</O< font>
<O</O< font>
EGT Pre DPF – EGT 13 –<O</O< font>
Long Name (used in menus) – Exhaust Gas Temperature Sensor Pre DPF – EGT 13 6.7L<O</O< font>
Short Name (used in gauge display) – EGT 13<O</O< font>
Equation – (((F*256)+G)*0.18)-40.0<O</O< font>
<O</O< font>
EGT Post DPF – EGT 14 –<O</O< font>
Long Name (used in menus) – Exhaust Gas Temperature Sensor Post DPF – EGT 14 6.7L<O</O< font>
Short Name (used in gauge display) – EGT 14<O</O< font>
Equation – (((H*256)+I)*0.18)-40.0<O</O< font>
<O</O< font>
Exhaust Back Pressure – EBP –<O</O< font>
PID – 0173 – Still Testing - 221445? -<O</O< font>
Long Name (used in menus) – Exhaust Back Pressure Sensor 6.7L<O</O< font>
Short Name (used in gauge display) – EBP<O</O< font>
Max Value – <O</O< font>
Equation – ((B*256)+C)*0.03625<O</O< font>
<O</O< font>
Engine Coolant Temperature 1 –<O</O< font>
PID – 0105 – Done Testing<O</O< font>
Long Name (used in menus) – Engine Coolant Temperature ECT 1 6.7L<O</O< font>
Short Name (used in gauge display) – ECT 1<O</O< font>
Equation – (A*(9/5))-40<O</O< font>
OBD Header –<O</O< font>
<O</O< font>
Engine Oil Temperature – EOT –<O</O< font>
PID – 22f45c – Done Testing<O</O< font>
Long Name (used in menus) – Engine Oil Temperature Sensor 6.7L<O</O< font>
Short Name (used in gauge display) – EOT<O</O< font>
Max Value – 400<O</O< font>
<O</O< font>
Engine RPM – RPM – <O</O< font>
PID – 0c – Torque – Done Testing
Long Name (used in menus) – Engine RPM (Torque) 6.7L<O</O< font>
Short Name (used in gauge display) – RPM<O</O< font>
Unit Type – RPM<O</O< font>
Equation – ((A*256)+B)/4<O</O< font>
<O</O< font>
Fuel Tank Level – <O</O< font>
PID – 22f42f – Done Testing<O</O< font>
Long Name (used in menus) – Fuel Tank Level 6.7L<O</O< font>
Short Name (used in gauge display) – Fuel Level<O</O< font>
Equation – A*0.39216<O</O< font>
<O</O< font>
Fuel Rate KPL Average –<O</O< font>
PID – E5 – to make – Custom PID<O</O< font>
Long Name (used in menus) – Fuel Rate KPL (Average)<O</O< font>
Short Name (used in gauge display) –<O</O< font>
Unit Type – L/h<O</O< font>
Equation – ((A*256)+B)*0.05<O</O< font>
<O</O< font>
Intake Air Temperature – IAT –<O</O< font>
PID – 0f – Still Testing - <O</O< font>
Long Name (used in menus) – Intake Air Temperature Sensor 6.7L<O</O< font>
Short Name (used in gauge display) – IAT<O</O< font>
Max Value – 100
Unit Type – °C<O</O< font>
<O</O< font>
Manifold Abs Pressure – MAP –<O</O< font>
PID – 0187 – Testing -<O</O< font>
Long Name (used in menus) – Manifold Absolute Pressure Sensor 6.7L<O</O< font>
Short Name (used in gauge display) – MAP<O</O< font>
Equation – ((A*256)+C)*0.03625<O</O< font>
<O</O< font>
Speed Vehicle MPH (PCM)– <O</O< font>
PID – 0D – Testing – Custom PID<O</O< font>
Long Name (used in menus) – Speed 6.7L (PCM)<O</O< font>
Short Name (used in gauge display) – MPH<O</O< font>
Min Value – 0.0<O
[/center]
OBD Header –
<O</O< font>
<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
OBD Header –
<O</O< font>
<O</O< font>
OBD Header – 7E0
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
<O</O< font>
Max Value – 100
<O</O< font>
<O</O< font>
Min Value – 0.0<O
