Another trans ID thread
I came across a 3 sp manual in a '60 f100 with a long wheelbase and a 223. It needs some bearings and gaskets, but the price was right.
Here's the specs. 9 bolt rectangular side cover with AB-7222B F26 and 9M2 Top of main case AF-7006D-24 Bottom of main case 9M3 Front bearing support TAAA 7050(3?) unsure of last # Tail shaft 9K14 18(6?) WAR 7651 A I think it's a T87, but my knowledge of all things Ford is still in it's infancy. Thanks in advance also it isn't an OD trans |
If you are able to get the vin number from the truck it came out of, that may be your best bet. It can be decoded to tell what it is, I think. Unless it is not original to the truck.
Those numbers you quoted are most likely nothing but engineering numbers, not part numbers, and I will guess that NumberDummy will say that they are useless as tits on a boar for determining your transmission. Well, he might be more polite than that. It is either a light duty, or medium duty 3-speed - whatever those designations mean. |
T87D pics posts 6 & 7. One set up for column shift, the other floor shift:
https://www.ford-trucks.com/forums/1...-progress.html |
OK this one had column shift. I was gonna snag the column shift linkage but someone beat me to that. So we can safely say that it's light duty as it has the 9 bolt side load rectangular access. On the right track. What do I use for ordering parts? It atleast needs gaskets and possibly an input shaft bearing
Look for the model number cast into the side, seems like Borg Warner did that on their transmissions. T86, T85 maybe. I see you posted numbers already. Did you get them all?
Look about like this? I have some of the same casting numbers as you.
http://i1241.photobucket.com/albums/...419_142525.jpg http://i1241.photobucket.com/albums/...419_142443.jpg |
Fjones, that looks close. I may be able to pull the VIN off the frame tomorrow. That's IF the truck is still at Pull & Save.
Alright let us know! I have a suspicion that this transmission came with two different lengths of the tail part! I'm not sure about that though.
Originally Posted by FJones8668
(Post 12895822)
Originally Posted by ibuzzard
(Post 12892046)
If you are able to get the VIN number :-huh from the truck it came out of, that may be your best bet.
Your '59 VIN: F25C9RXXXXX / F25 = F250 / C = 292 2V / 9 = 1959 / R = San Jose CA Assembly Plant / XXXXX = 1959 Numerical Sequence of Assembly. Where is the TRANS code...no see um. TRANS code listed separately on Rating Plate (1948/60), Warranty Plate (1961/79), Certification Label (1980 to date).
Originally Posted by vntgtrk
TAAA-7050-3 :-huh
Different extension housing lengths = different wheelbases / Warner T-87 H/D 3 speed: 1957/60 F350 292 only. Bearings/cups have BIN's (Bearing Industry Numbers) stamped on them, what autoparts stores/bearings shops go by. C3AZ-7025-B .. Front Bearing = BIN: 15039 or 550010 or 550301 or 207-L // 51A-7065 .. Rear Bearing = BIN: 15040 or 306-L Take a look-see in this trans, these are the two ball bearings required. Will also need front/rear seals, aforementioned gasket set. And, 1952 was the last year that a 3 M/T was available in a truck w/a floor shift. |
Once again, NumberDummy saves the day! This trans came aot of a lwb and I'm attemting install on a swb. I'll have to get out the guessing stick to see if I have enough room.
(Post 12898140)
Well after some measuring it's clear that I would have a clearance problem with a Xmember and the drive shaft would be way too short for my liking. But I know what it is now. I did keep the bell and the shift linkage. So when I find a T87 for a short bed, I'm gonna go that route. 3 on da tree sounds good to me
Is bolt pattern of that 3 speed same as T5? Shaft length same?
Originally Posted by Damifiknow
(Post 13042642)
